Sharp mx m55on
Can we load a TWAIN driver on this model? If so, how? and or is it already loaded with that driver?
coolcat_12
  • 259 Answers
SOURCE: polaroid camera not windows nt compatible
Starting from the start plug in the device and XP will detect and look for new drivers a search for drivers is usually done in the inf directory under windows or winnt directory If a driver is not found the computer pops up a question did a Cd or software come with this device if you install the software the a reboot is usally needed if you do not do a reboot you can try once the drivers have been installed unplug the device and plug it back in again the computer will search for the new drivers that are installed and should set up the device to work If it does not work you will need to get driver for the device that will work with XP I have a scanner than need XP drivers but will work on one of the older computers but not XP
Posted on Jan 11, 2009
  • 37 Answers
SOURCE: The twain driver is not loaded and i cant find it?
You need to download a program called network scangear. After installing scangear run the program and let it find your copier, then just select it. the file is NWSG_v2.23.exe and can be downloaded from here http://www.usa.canon.com/html/download/canonnetutils.html
Posted on Jul 30, 2009
  • 87 Answers
SOURCE: my canon 5000f will not work with vista 64
Sorry to inform you, but there are no Vista x64 drivers for that product, according to Canon's website.
Posted on Aug 06, 2009
linswad
  • 258 Answers
SOURCE: down loading
ASUS have a good support website at http://support.asus.com/
Go there and choose Download, then enter details for your board and Operating System.
Posted on Apr 11, 2010
  • 15 Answers
SOURCE: How do you load standard sized envelopes into a
long ways in the cassette, unless you have a bypass tray, make sure to change your cassette setting under systems settings, tray settings.
Posted on Sep 09, 2010
Ar M55on Keeps turning itself off and on
Machine is trying to load toner .just let it continue until it gives
an error code otherwise ..
Dec 03, 2013 | Sharp AR-M355N Grayscale Copier
Sharp MX-2300N Color scanner can't find network
Drivers are for print functions only (or twain scan via USB). Check for bad cable, port, or jack. Could be another device on the network is being handed the IP of the copier via dhcp (or vice versa) can you ping it from a workstation? I have also seen the dell network assistant utilities on some dell workstations cause issues like this.
Jan 11, 2013 | Sharp MX-2300N Color Copier
I installed the Driver for my Sharp MX-2700G on my new Macbook Pro (OS 10.8). I see the printer but cannot print. Anyone can help please?
usually after installing the correct driver and it finds the printer and ip address and loads in and then a test print is done and nothing comes out then look for the model again and find sharp sap driver that is associated with your model and windows version not forgetting 32bit or 64bit. The driver will look the same but will have sap in the title. once tested and working remove the original printer you installed as it will never work.
Nov 06, 2012 | Sharp MX-2700N Color Copier
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
I LOST MY P5S MX SE CD..HOW CAN I DOWNLOAD THE RIGHT DISPLAY DRIVER AND THE AUDIO DRIVER??
hi hector, i am happy to assist your , copy and paste the link i have given below
http://www.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6
i have already select your motherboard model , after page loaded you can able to see your motherboard model, scroll down in the heading tab there is option called DOWNLOAD click it.
Select your OS model in Operating System, now all your drivers are been displayed below click and install it
Good luck
Jan 12, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Keeps saying "scanner failure" What do I do?
Scanners are a real legacy issue within windows - they have been there forever and yet the software controlling them hasn't been improved on - TWAIN it is the name of the Toolkit which communicates with your scanner and the proprietary software sits on top of that. TWAIN stands for "Toolkit Without An Interesting Name" - I think says it all. It hasn't been improved on much through the various releases of Windows. But to help you more we would need a lot more information.
- Platform Windows 7 .... Mac ...
- Scanner name and manufacturer
- Type of connection to the scanner ( USB ¦ WIRELESS )
- Whether you have had the scanner working in the past on this machine.
- Does the scanner work on another machine - Do you have another machine on which to try the scanner.
- Do you have the original disks for the scanner. And the original Windows Disk - so that you can load up the TWAIN software.
- How did you install the software for the scanner
- Have you come across this TWAIN driver ( perhaps you haven't installed that - because the Manufacturer's software doesn't include the TWAIN driver ( you have to load that from your Windows disk )
If you haven't loaded the TWAIN software - then perhaps - you should de-install the Manufacturers software and then install the TWAIN driver from the disk ( although - it may already be resident in the bowls of the Windows environment on the machine ) and then finally re-install the Manufacturer's software ...
So more questions than answers - but I hope that helps ....
Greg McC
Jul 02, 2010 | HP PSC 750 All-In-One InkJet Printer
How do you load standard sized envelopes into a Sharp MX-2300 copier?
Use the Bypass tray to load it. But first try the paper tray and try to load it there and see if the paper tabs have a size adjustment for envelopes. If not try the by pass
Apr 10, 2010 | Sharp MX-2300N Color Copier
Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Nov 18, 2007 | Canon CanoScan N656U Flatbed Scanner
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
