Question about Xerox Phaser 8560MFP Laser Printer
Error msg 13,200.41:27966
I have a phaser 8560 and in the middle of the night, it started making noise, then had error code 13,200:41:27966.
  • Xerox Contributor
  • 185 Answers
The printhead has problem gone bad. The error 13,200 tells us that right jetstack is over temperature and shut down. (27966 is your page count)
You probably need to buy P/N 017K04540
Posted on Jul 31, 2009
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
Note
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Oct 14, 2014 | Xerox Phaser® 8550, 8560, 8560MFP Extended...
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
09,035.43:46672 this is an error message i get on my xerox phaser 8560... can you tell me what it means?
If after following mariolands advice the problem continues, you will need to replace the ink loader, for the 8560 ,the part number is 133K27771. Here is a video that will show you how. The video also covers the 8400, 8500, and 8550. Though the part numbers are different the procedure is the same. ">
Jan 30, 2011 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
Whats the 09 007 42:4609 error code mean on my
The machine thinks the yellow ink chute isn't working. The inkloader may be jammed or defective.
If you can't un-jam it, you will need to replace the inkloader.
-Whit :)
Jun 30, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560MFP Laser Printer Logo
307 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
