Question about Garden
Added new spark plug, fuel line is clear, start cable moves, new oil
Will not start
  • 246 Answers
Hello:
>>Here is a Basic Instruction File I am in the Process of Making. It will Might Say Mower, but a Snow Thrower/Blower is Powered by the Same Type of Engine, so the Diagnostics are Basically the Same. >>***Here are some Diagnostic Instructions to Do on the Engine to Locate the Cause/Cure for a Hard/Not Starting Engine. This Does Not Include a Problem with the Valves. If I Suspected the Valves are Involved, then a Separate File for the Valves will be in this E-mail. This is a File in the Making, so Any Input is Appreciated.
>>1- Check the Spark. If Not Firing, then Replace the Plug.
>>2- If the Plug is Firing, then First, Pour a Small Amount of Gas (1oz) Into the Carburetor Throat with the Throttle at Full. With the Throttle Still at Full, Try to Start the Engine. If the Engine Starts and Quits, then Make Sure the Gas is Free Flowing to the Carburetor. If the Gas is Free Flowing, then Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl, Float Pin, Float and Needle Valve and Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. Then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air. Install New Parts if Required.
>>3- If No Fire at the Plug, then Remove the Coil Shut Off Wire from the Kill Switch at the Engine Stop/Brake Bracket (where the End of the Stop/Brake Cable Attaches at the Engine). Check for Fire. If No Fire, then Remove the Blower Housing and Remove the Ground Wire from the Coil. Check for Fire. If Still No Fire, then the Coil is Bad. *On Some JD Model Mower the Engines Use an Igniter. Remove the Igniter and Coil and have your Local JD Dealer Test them for you.
>>* **On Models with Point Set, the Condenser is Bad and the Point Set and Condenser should be Replaced as a Unit. Make Sure the Point Set Plunger is Fully Extended when Setting the Point Set Gap to .020in.
>>** If there was No Response from the Engine When the Gas was Poured Into the Carburetor Throat and the Plug was Firing, then Check the Compression. If the Compression is Good, the Carburetor has Been Soaked and Cleaned and the Plug is Firing, then Check the Flywheel Key. If the Key is Damaged, then the Plug Firing is Incorrect to the Position of the Piston During the Compression (Power Stroke).
>>*** On the OHV and Some L-Head (Flat Head) Engines there is a Compression Release. The Exhaust Valve Clearance has to be Opened to .020in for the Compression Release Not to Operate; in Order to get a Correct Compression Reading.***
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
Why will my saw not start, good spark new plug fresh gas
Sounds to me like a plugged up fuel line or old fuel in the fuel line. You may be able to clear it by spraying some starting fluid into the carb to pull the old fuel through. You only want to do this 2 times because this has no oil in it. Another suggestion it to remove the spark plug and put some of your fresh fuel mix directly into the chamber. About an eyedropper full should work.
Jul 13, 2015 | Makita DCS6401 20 20",64cc Chainsaw 2...
The 173cc OHV is new but it has been inactive for a few years and willnot start
Drain all old fuel out, check the fuel lines are clear to the carburettor make sure the needle valve is free moving, remove the spark plug and check it is clean and no rust on points. Insert a couple of squirts of engine oil from an oil can in the plug hole and rotate engine several times with plug out. The faster the better. If too much oil the plug will clog and not work, so be gentle with application. Squirt a little petrol [half a teaspoon is enough] and then fit sparkplug. Then start engine in usual way. Note that some fuels become unuseable after a time.
Aug 23, 2014 | Garden
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
Troy Bilt self propelled lawmower won't stay on. It's been fine this year, today all I did was add gas and added the mulch shoot. I turned it on, it was fine. Started mowing, got halfway across...
The trouble you are experiencing could result from several different things. First, check the oil when the engine is cold and completely settled in the sump. You do not want to overfill the engine with oil. If the oil is on the full line (not above it),then the low oil sensor is not shutting off your engine. The oil level should be exactly on the full line-not above or below. Second, remove the spark plug and clean it with a small wire brush or sandpaper. If you are unsure about how to clean the spark plug, replace it with a new one. If both of these procedures have been performed and the mower still doesn't run correctly, the problem is almost certainly with the fuel supply, fuel quality and/or carburetor.
Jul 30, 2017 | Troy Bilt 5.5hp Self Propelled Mower
Won't start. changed gas. oil is okay. added fuel additive. new spark plug.
Ensure choke is turned on while starting.
Ensure spark lead is fully pushed onto plug.
Remove spark plug and check there is a spark by keeping spark plug against body of engine and cranking engine, if no spark check there are no broken wires in ignition circuit.
Loosen bolt on float bowl. Fuel should start leaking from around top rim of bowl, if it doesn't then there is a restriction somewhere in fuel line or float valve is blocked in bowl.
Feb 21, 2011 | Coleman Powermate Premium Plus 6250W...
Laid mower on right side towards spark plug fixed fuel line won't start changed spark plug
if turned on side with air filter down check to see if filter is oil soaked if so replace. also carb bowl may have oil in it. clamp fuel line remove bowl nut and drain. will smoke when starts but will clear out
Jul 17, 2010 | Toro Garden
My 14SB John Deere mower will start but then quits before moving the throttle, changed oil, oil filter, spark plug, new oil, added fuel stabalizer to gax tank. Any ideas???
Hello. You have some winter buildup in your engine. Get a can of starter fluid and a helper. have the helper shoot small squirts of starter fluid into the air filter while you run the mower. In just a couple of minutes the starter fluid will clear your problem. Joe
Apr 25, 2010 | Garden
Bike has sat up for a year or so,wont start,cranks fine,has spark,maybe bad fuel ?
If no fuel stabilizer was added while the bike sat for a year or so.
It is most likely bad fuel with gum deposits.
This can can create some problematic symptoms for you.
It is vital the bad fuel to be cleared from tank/lines and carbs.
You may need the fuel system cleaned as the gum deposits can cause major headaches in the carbs and jets. If the system is not cleaned and even after you get the bike running, you could be miles away and have the fuel fowl jets/injectors, causing shut down.
Check the spark plugs carefully. Oil on the plugs may just need cleaning. Once you get the bike running the oil should burn off if the rings are still in good shape.
Motor needs clean Air, Clean Gas and a hot spark.
Oct 04, 2009 | 1995 Yamaha XV 535 Virago DX
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
