Question about Microsoft MN-700 Wireless Router
Galaxy s4 wont connect to Microsoft MN-700 router
The phone sees the router... says it's "saved" and "secured" but then never will connect. Says it's searching for an IP address and will never actually connect.
5 Suggested Answers
  • 3 Answers
SOURCE: new pc.. old router. not detecting internet
i'm using the MN-100 router right now and it works perfect with Vista! with DSL PHONE LINE
log into your base station(MN-100) defualt password is: admin
1. Make sure 'DHCP server' is set to 'Enabled'.
2. 'Network Mode' setting must be set to 'Routing mode'.
3. Works with Firewall enabled.
GO TO the page (Wide Area Network (WAN) Settings
enable: PPPoe-uses point to point protocal over ethernet
then below that enter user name & password same as you did the first time you used your DSL i include (MY)service name too(SBC Global) when done go back to home page click connect may take a min or two your done! after initial setup is done its fast and you dont have to put user name or pass in again either!
Posted on Feb 22, 2009
kakee
  • 1269 Answers
SOURCE: Mn-5oo
Just open Internet Explorer and type http://192.168.2.1
When you get to the setup page of the router, look for Wireless tab, then Wireless Security. Select WPA-Personal or PSK and type your password on the passphrase or passkey box. Save the settings. That's it, your wireless network is secured
Posted on Apr 01, 2009
RickOz
  • 145 Answers
SOURCE: The driver of Microsoft MN-700 router
There is no driver required. Configuration of the router is done through your web browser. The address is 192.168.2.1. It would be best to do this via a cable connection as the wireless mode may or may not be enabled. If you do not have the users manual, here is a link to download it: http://download.microsoft.com/downlo...tion_guide.pdf
Good luck
Posted on Apr 17, 2009
  • 154 Answers
SOURCE: How do I manually add a device to my MN-700 router
The static ip address is set on the device itself, not the router.
You will need to make sure the ip address and subnet mask you specify for the device is in the same network range as the router.
Ex. MN-700 router IP Address 192.168.1.1
Mask 255.255.255.0
New device IP Address 192.168.1.5
Mask 255.255.255.0
If the new device is a pc, you will also need to enter the DNS settings provided by your ISP to be able to connect to services on the internet.
If you have any additional questions, please post a reply.
If you feel this information is helpful to you, please take a few minutes to rate this reply.
Posted on Aug 30, 2009
I cant connect to friends on xbox live i have a microsoft mn-700 router
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then contact the Router manufacturer and Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Dec 24, 2010 | Microsoft MN-700 Wireless Router
How do i set up a secure connection with m microsft router?
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Aug 29, 2010 | Microsoft MN-700 Wireless Router (p5308j)
How to find my security key for wireless internet
Reset your router and reconfigure the wireless network
Mar 26, 2010 | Microsoft MN-700 Wireless Router (p5308j)
Setting password
hi find the link bellow for the router and have a look in wireless security i believe page18
download.microsoft.com/download/B/6/9/B69C956C-85D9-4641-AA6F.../MN700_Base_Station_Configuration_Guide.pdf
Regards AL "alstech"
May 26, 2009 | Microsoft MN-700 Wireless Router
MN-700 needs constant re-setting
probably overheating u may need to get a new one. :(
May 24, 2009 | Microsoft Broadband Networking MN-700...
Good luck
Apr 17, 2009 | Microsoft MN-700 Wireless Router
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Microsoft Wireless-G Base Station MN- 700
Just remove the router and reinstall it. it will ask you for new Base name Etc and new wirless network name with new security key codes.
Aug 20, 2008 | Microsoft Broadband Networking MN-700...
Getting dropped by the MN-700
try latest firmware update ok see if that fixes the issue microsoft.com site or custum windows update then re do settings u dont relly need 256 bit man ok 1268 fine with reg password
Mar 13, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Microsoft MN-700 Wireless Router Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
