Question about Mesa 2 Hour Fire Safe 4.0 Cu. Ft. Electronic Mfs100e
Santul safe continually beeps - Mesa 2 Hour Fire Safe 4.0 Cu. Ft. Electronic Mfs100e
Tip
PS3 Safe Mode
Sony PS3 Safe Mode
If you choose to perform one of the Safe Mode options, please back up your data before attempting to enter safe mode (when possible).
Safe mode is a feature for starting the PS3 system with the "minimum required functionality" if the system is no longer able to start up normally due to an action that was taken.
In Safe Mode, you will have the following options:
  1. Restart System - Ends safe mode and starts up the PlayStation 3 normally.
  2. Restore Default Settings - Performs the same operations as [Restore Default Settings] on the XMB, and also deletes PlayStation®Network account information from the system.
  3. Restore File System - Attempts to repair all areas on the hard disk drive where files can be saved. Corrupted data may be erased if it cannot be recovered.
  4. Rebuild Database - Deletes messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information.
    This operation may take a long time depending on the type and number of data items.
  5. Restore PS3 System - IMPORTANT: All data will be lost by performing this step.
    This will reformat the hard drive on the PlayStation 3, deleting all data and restoring it to as if it just came out of the box. This is the same as [Restore PS3 system] on the XMB.
  6. System Update - Updates the PS3 system software. This can only be done with an update file already saved on an external storage media.
To activate Safe Mode, follow these steps:
Step 1: Turn off the PlayStation 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PlayStation 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
4. Connect a USB cable to the controller and the PlayStation 3 and press the PS button to enter Safe Mode.
5. Then you will see the Safe Mode menu.
Sony recommends performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
I hope that helps.
on May 08, 2010 | Sony Playstation 3 (PS3) Console
How to enter safe mode on my ps3
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
Apr 24, 2014 | Sony Playstation 3 (PS3) Console
I have a Santul Safe, Model 8200 and have no idea what the combination is, so I can;t open it....are you able to assist...?
it is from the factory 5555 or 555. What I don't know how to do is change the damn password!!
Jun 15, 2011 | Office Equipment & Supplies
Toshiba laptop running w7, when i turn laptop on it goes straight to start in safe mode or normal, tried safe mode but get a continuous beep, then it switches off, then turns itself back on again, with the...
Thats because your lap top needs to be reebooted in a format to reconfigur itself unfortunatly its not doing that please! do an early system restore to when it was working and save those settings for the next time this happens ok! and save all your current files just in case you need to wipe your whole drive to origibal settings ok!
Mar 26, 2010 | Computers & Internet
All the connections work the ps3 comes on but then goes black
You may have messed up the Screen-Settings, to solve this try this.
Step 2:
Step 3:
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  3. Rebuild Database
  4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not go to main menu
Have you tried a Database Restore from Safe Mode? :o)
Step 2:
Step 3:
Step 4
  3. Rebuild Database
Oct 07, 2009 | Sony Playstation 3 (PS3) Console
Playstation Update was interrupted. Now when PS3 is turned on i won't load the main menu stays on the wavy line screen
you can turn your system settings back to factory default using the Safe Mode.
Step 2:
Step 3:
Step 4
  3. Rebuild Database
Oct 06, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    Step 3:
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    3. Rebuild Database
    Oct 04, 2009 | Sony Video Game Consoles & Games
    No picture for ps3,i went to service menunand did something wrong
    You probaly turned hdmi on or off i dont know what your settings is,
    Step 2:
    Step 3:
      safemode2.jpg //
    3. Rebuild Database
    Oct 04, 2009 | Sony Playstation 3 (PS3) Console
    Mesa 2 Hour Fire Safe 4.0 Cu. Ft. Electronic Mfs100e Logo
    35 people viewed this question
    Top Mesa Home Security Experts
    Lawrence Oravetz
    Are you a Mesa Home Security Expert? Answer questions, earn points and help others
