Question about Refrigerators
Fan in fridge works but the fridge doesn't get cold. It's a small sunbeam fridge.
  • 544 Answers
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks
Posted on May 08, 2009
  • Corey Haugen May 17, 2013
    Hi Mark, I have a Sunbeam Mini fridge as well. It sounds like its running but the fridge wont get cold. It was on its side for half the day. Is there a fix for this?
Freezer works but fridge doesn't for Doc Henn. I couldn't see your video but more common reason for this would be the small fan usualy behind the inside back panel of the fridge. The freezer is the pa
Check to make sure the light in the fridge shuts off when the door is closed. You'd be surprised how much heat is given off by that light. If it stays on either take it out or replace the switch.
Apr 02, 2013 | Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
G,DAY. my fridge which is a hff518w does not get cold in the fridge compartment, the freezer works well.I have tested the fan on the bench and it works well but it wont run when hooked up to the fridge.I...
I think that now that the timer has been opened it needs to be replaced. However the timer doesn't generally shut of just the fan, it's designed to stop the compressor from running and turn on the electric defroster.
Most of the time that a freezer gets cold and the fridge doesn't means that you either have a bad cooling fan or a blockage from ice. A complete defrost will ensure it's not a clog.
Even bench testing the fan is not a full proof test. Usually when you test the fan its in room temperature air and most people test the fan laying down.
The fan operate on very small bearings which are very sensitive to temperature, so testing a fan outside the fridge, you would need to test it in a cold environment and move the fan in multiple directions.
I would suggest that you purchase both a new timer and a new fan.
These items can be purchased at your local appliance dealer or online at applianceparts.com.
Thanks for your question.
Aug 24, 2011 | Refrigerators
I have a 5 yr old side by side fridge. just a couple of days ago I noticed that temp. in the fridge was way too warm. Freezer is fine, but when I felt for any kind of cool air circulating into the fridge...
frost on the coils means the compressor is working and it is making "cold" if the cold isn't getting to the fridge side the fan the brings the cold air to the fridge side is ethier blocked off or not working. If you have a small thermomator use it to check the fridge side apx 38 to 40 degrees is the "food zone". the fan is usually not to expensive and often not that hard to change. there is a timer that defrosts the coils usually about once every 24 You may see a small knob on the defrost timer. watch its position over several hours and you should see it move position. if it doesn't move then the defrost timer is faulty. the most expensive part of the system is the compressor and it sounds like that part of your system still functions. If the freezer is getting plenty cold but the fridge part is not cooling off you have an air flow problem. It is not uncommon for these fans to make noise and then fail altogether.
Apr 21, 2011 | KitchenAid KSCS25FKSS Side by Side...
The fridge isn't as cold as it should be, all seemsto be working, but upon removal of the inspection cover inside the fridge, it appears that the small 12v fan isn't working. should this fan always be...
Seems to be a common problem. Same problem with our fridge. (10 minutes to fix = apprx. $200) One of the wires for the fan breaks. I suspect F&P know about this and I suspect are making a lot of money in repairs
Nov 29, 2010 | Fisher and Paykel Active Smart E522B...
Simpson fridge stopped working. The freezer still goes but not the fridge part. At the time the power fuse box overloaded (around the same time as the fridge died). Not sure if that was connected but power...
If this is a standard upright fridge (freezer at top), then the usual principle applies: cold air drops.
A small fan (situated between freezer & fridge) should be functioning, which forces cold air from the freezer, down into the refridgerator.
I would recommend you first determine if this small fan is operating (this is the noise you would normally hear, when you open the freezer door) and if not, then replace the fan.
If fan is working, then I would suspect a faulty thermister which would require a technician.
With repairs of older devices, it's always best to obtain quotes first, as often the cost of repair could well amount to up to 40% of the price of a new one.
Good luck...
Feb 14, 2010 | Refrigerators
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
