Question about Cambridge Soundworks 88CD CD Player
No power when we plugged it up after being unpluged for a day or two, model 88CD
Digital display goes dark from time-to-time...
Most likely its the digital display is burnin out, If your farmilar with electronics and soldering, you can just order the part and replace it yourself. If not shop around for a cheaper rrepair technician in your area.
Nov 13, 2007 | Cambridge Soundworks 88CD Clock Radio
WHAT IS THE BATTERY FOR HENRY KLOSS 88CD DISPLAY
I think the only battery are on remote controlbattery with a 3 volt CR2032 battery.
Mar 05, 2012 | Tivoli Henry Kloss Model Two FM/AM Radio
My Cambridge SoundWorks 88CD is not working...no display, no sound, the CD doesn't spin. Any hints? Thank you.
A couple of possibilities- If there is no fuse holder on the rear of the box, it may not be user-replaceable but soldered onto an internal board. If it has blown, either there has been a component failure in the power supply that caused the fuse to fail or the supply is not starting up as it should, a problem caused by cheap capacitors in certain areas of the supply. Unless you have at least a multimeter, this is not a good choice as a DIY repair.
Jun 17, 2011 | Cambridge Soundworks 88CD Clock Radio
I would like to obtain SERVICE/REPAIR manuals for my Cambridge Soundcraft 88CD and CD740 clock radios. Thank you! Don
I don't believe you will find the Service Manuals generally available online. You would likely need to obtain these from a technician working in an authorized dealer location. If nonone has been able to respond to your request at this point I would recommend you contact Cambridge Soundworks directly to see if they can and are willing to provide. Their contact information can be found here:
http://store.cambridgesoundworks.com/content/about_contact.htm
Jun 08, 2011 | Cambridge Soundworks 88CD Clock Radio
I cannot connect to my wireless network.
Try choosing the option "Repair" in your task bar. If that doesn't work, most of the time simply unplugging and replugging in your router from the power supply will do the trick.
Mar 01, 2011 | Linksys Wireless-G WRT54G Router
How do i down load a manual for the henry Kloss 88cd radio?
You can get the manual on the link below. Scroll down to product details. Then click on the manual link.
http://www.amazon.com/CAMBRIDGE-Model-Table-Radio-Henry/dp/B000069APY
Feb 05, 2011 | Cambridge Soundworks 88CD CD Player
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
Dim display on Cambridge Soundworks 88CD
I can't find a manual for this but my guess would be there is a setting for the Display to dim it at all times unless you touch a control.
Feb 26, 2010 | Cambridge Soundworks 88CD CD Player
Can I still get the remote that goes with the 88 CD model?
it could be possible you can try on ebay and see if someone is selling there old one
Jan 14, 2010 | Cambridge Soundworks 88CD CD Player
Cambridge Soundworks 88CD CD Player Logo
77 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
