Question about Stanley Proto Stanley TR150HL SharpShooter Heavy Duty Staple Gun
Getting staples to sit flush - Stanley Proto Stanley TR150HL SharpShooter Heavy Duty Staple Gun
How to shoot staples out of a trutac staple gun
Hello, there. The TruTac (TT50) is a bottom load staple gun. This video on the TruTac (TT50 and TT21) may help to answer this and other questions: http://bit.ly/1Xv7jeZ. Once the staples are loaded, keep the tool flush with the surface while stapling. If you have any more questions or need more detailed instructions, please contact us at customercare@arrowfastener.com. Thank you!
Jun 07, 2015 | Arrow Fastener Staple. TruTac Forward...
I have a Staples SPL77M shredder. It stopped automatically feeding paper when placed in the feed slot and now requires the forward button be pressed and held down to shred paper. If the on/off switch is...
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Dec 02, 2014 | Staples Office Equipment & Supplies
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Problem with the Stanley Tools TRE550 Electric Staple/Brad Nail Gun Cannot get the staple drive flush help me please
First, try holding the stapler very firm to your project and make sure that the piece that you staple in to is backed solid with no give or springiness.
second, you might try shorter staples,or . . try dialing in more tension by turning the big knob on the back end that has the "+" "-"
Sep 11, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
Brand new out of package loaded with correct staples.... unit does not work
I had one. didn't like it.they are herd to squeeze because they work backwards compared to a regular staple gun. Take it back for a refund,tell them it is not what you wanted. They never get staples to go flush with anything you use it on.Buy a Craftsman or a Arrow.I gave my Powershot away, and the person I gave it to threw it away.
May 31, 2011 | Black & Decker 5700 Powershot Forward...
I am having problems getting the staple to go all the way in -- recovering dining room chair seats. I have lost the manual -- does the dial with + and - have something to do with it? Stanley TRE500...
Hi Rita,
Yes, the + and - adjusts the depth of the staple. You should check the setting periodically as it has a tendency to move as you handle the stapler.
Also, holding the nose of the staple flush and steady on the surface helps to drive them to the proper depth.
Hope this helps. If it does, I'd appreciate a 4 thumbs up, keeps me working... Thanks,
Handie Andie
May 08, 2011 | Electric Stanley Tre500 Staple Gun /...
I can't get it to spit out staplers
staples don't go into wood flush and even. they bend.
Dec 08, 2009 | Stanley Staple/Nail Gun Elec
Arrow et2025Hd staples won't go flush
The material you are putting staples into is too hard for this little staple gun.
You will need a more powerful stapler, such as a staple gun that uses compressed air to drive the staples and where you can adjust the air pressure.
Apr 30, 2009 | Tools & Hardware - Others
Staple problem
pull about 1 inch of staples out of the cartridge, tear off the 1 inch so new staples are flush with plastic cartridge. Reinstall and make 10 stapled sets. By the time it tries to staple set number 3 or 4 you should start to see the staples working. It could take as many as 8 or 9 sets for the staples to advance far enough. Once it staples you are all set/
Mar 19, 2008 | Sharp AR-407 Copier
Stanley Proto Stanley TR150HL SharpShooter Heavy Duty Staple Gun Logo
49 people viewed this question
Top Stanley Proto Tools & Hardware - Others Experts
John Trevino
Are you a Stanley Proto Tool and Hardware - Other Expert? Answer questions, earn points and help others
