Question about Acer Aspire X3200 PC Desktop
One single short beep pc turns off for some sec and turns on repeating th beep
  • 115 Answers
Most probably your processor is getting overheated due to dust on the cooling fan and heat sink. Remove them and clean. Before putting them back remove old thermal pase and apply fresh one. If you are not familiar with these things then go to a technician.
Posted on Nov 26, 2013
Installing new motherboard, processor, mem, and video adapter. Powers on but no post.
If the beep is a very high pitched tone, turn off the computer. Your CPU is overheating. The thermal paste may not be spread correctly on the CPU or the heat sink isn't properly installed.
Otherwise, it's probably a memory error. This machine takes 2 GB of memory as 2 single GB memory sticks. Try booting the machine with only one DIMM installed. Try each stick individually before getting replacement memory.
I hope this helps.
Jan 27, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Ep-8hmmi-a socket 754 when i turn on the unit it keeps on beeping....please help me what will i do
As per your error code it is related your system memory. Replace the system memory, it will solve your problem positively
Nov 17, 2011 | Computers & Internet
Why does my computer beep when I turn it on?
Here is a list of what beeps may mean:
1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU 1 short DRAM refresh failure 2 short Parity circuit failure in the first 64KB of RAM: Likely a bad RAM IC, or possibly one of the hardware tests has failed
Once you have identified what the beeping means you should contact the type of pc you have and ask what to do.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
What does 4 Short beep, 1,5 sec silence, short beep, 1,5 sec silence, 1.5short beep, 1,5 sec silence, mean and hoeto fix
most acers use phoenix bios chips.
Here is a list of the beep codes.
reference yours to this webpage
http://www.bioscentral.com/beepcodes/phoenixbeep.htm
as soon as you have found the corresponding codes you can place it here for us and we can then proceed from there.
Oct 12, 2010 | Acer TravelMate 240 Notebook
Short beep, 1,5 sec silence, short beep, 1,5 sec silence, short beep, 1,5 sec silence, short beep, about 3 sec silence and then complete shutdown
There is a problem with the laptop that is why you get the short beeps and then it shuts down.
The problem mainly is that, the components in the laptop are not sitting well or there is a faulty component in it. So it is not able to run a full loading of the operating system.
Have a repair man assess the RAM and other components in the laptop like the Hard disc and the rest. Remove them and install them back in.
Any fault detected should be corrected.
Take care
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
hi,
please write your beep description
ex: one long beep two short beep
repeating short beep
Sep 11, 2010 | Gateway 838GM (RB838GM) PC Desktop
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Screen stace dark, motherboard beep 20 sec long beep then
there may be problem with your RAM or processor
please check the on your friends pc
May 06, 2010 | Computers & Internet
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
Acer Aspire X3200  PC Desktop Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
