Question about Dell 0Y3740 Keyboard
Want to make a degree symbol - Dell 0Y3740 Keyboard
  • 2,113 Answers
With num lock on using the right keypad only type alt + 176
I leave a notepad of characters that i can copy and paste from to be faster. To do any alt code google alt codes
Posted on Nov 26, 2013
My refrigerator is a double door and top portion is not cooling yet it reads 38 degrees. Why is it not cooling?
unplug the power cord for 10 minutes, then set again the thermostat at your temperature required.plug it again and wait for two hours.
Dec 31, 2014 | Refrigerators
Why is a degree symbol not considered an English character on Fixya?
Unfortunately with new technology comes difficulties that require adjustments. For the most part, spelling out data is preferable to using sysmbols.
Jul 06, 2013 | Keurig Elite B40 Coffee Maker
Ti 84 mode a+bi you can not add 5 at 90 degrees to 5 at -90 degrees. You need to switch to exponential mode e^ and enter as 5 e^(pi/2i) this is ok for 180 degrees. however what do you do when...
You can add angle measures by hitting 2nd angle and choosing the degree option. Put this after a value (e.g. 90(degrees symbol)) and add you can add angles that way. Be sure that you are in degree mode when doing this (you can use the radian symbol for adding radians too). Still, this is a very tedious process and I recommend just adding angles as regular values (e.g. 90 + 200 = 290) and correcting for degrees manually.
Feb 21, 2011 | Texas Instruments TI-84 Plus Calculator
How to open autocorrect option ; how to put degree
You click on the Office button, top left corner, then select Word Option then Proofing and click on Autocorrect option.
Also here is all you need to know about the Autocorrect function in Word 2007, in a short video
You can easily insert a degree symbol in your Office documents going to Insert menu, using the Symbols command and then insert the degree symbol.
Dec 19, 2010 | Microsoft Office Computers & Internet
How do I create a superscript e.g.for a degree symbol?
DEGREE AND OTHER SYMBOLS ARE LOCATED IN OFFICE SOFTWARE LIKE MS WORDS. IN WORDS YOU MAY PRESS "INSERT" THEN "SYMBOLSmoz-screenshot.png" THEN CHOOSE YOUR SYMBOL THEN ENTER
Aug 16, 2010 | NEC SuperScript 860 Laser Printer
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
How do I get from degrees to radians? For some reason my TI-84 will not convert degrees to radians.
Press the [MODE] key to access the mode comfiguration screen .
Set angle unit to to radian (see above)
Enter angle value in Decimal degrees only, use the [2nd][ANGLE] key sequence to have access to the degree symbol. The degree symbol must imperatively appear at the end of the angle value.
Here are some examples
If you use angle values in DMS, it will not be converted to radians, but to decimal degrees.
If you omit the degree symbol there is no conversion.
A general formula is Pi radians =180 degrees
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Converting between Decimal Form and Degrees, Minutes, Seconds
Enter the angle in degrees-minutes-seconds using the single-tick (') for all three parts. Do NOT use the degree and second symbols. In my TI-86 manual, it's on page 285.
Jan 15, 2010 | Texas Instruments TI-86 Calculator
Keyboard
You don't say what make and model so generally there is either a key with a degree symbol or it is on a keytop in a different color this means tou must use the code or alt. key with it.
DickyO
Dec 20, 2007 | Office Equipment & Supplies
Dell 0Y3740 Keyboard Logo
54 people viewed this question
Alun Cox
