Question about Ricoh Office Equipment & Supplies
Ricoh Aficio 220 - moved copier to clean behind
Ricoh Afficio 220 - moved copier to clean behind it - now have mechancial/electrical? clicking sound and copier is not doing its startup cycle through. When I open front door the sort tray moves and the LCD operating screen comes on to show door open. I close the door and it goes right back to clicking sound.
  • 469 Answers
Check the power cord, make sure you have not just pulled the copier end out of place. the power cords are often replacable and can pull out of the copier.
Hope this is of some help.
Ed
Posted on May 08, 2009
Functional problem sc302 in ricoh afficio 1315
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Oct 22, 2013 | Ricoh Aficio MP 1600 Black and White...
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
I have a Ricoh Aficio 220 and after moving it to a new location, it leaves a blank strip on the right side of each page.
There is likely toner on the laser shield glass. The laser shield glass is located just below the toner hopper -- should be covered by a small plastic cover held in by 1 screw. Remove this screw, pull off the cover, and gently slide the glass strip out. Clean the glass with a dry lint-free cloth then reinsert it and put the cover back on. Your blank strip should be gone.
Feb 21, 2011 | Ricoh Aficio 220 Laser Printer
I need "USB" driver for Ricoh Afficio 1515MF
http://support.ricoh.com/bb/html/dr_ut_e/re/model/x15_15f/x15_15fen.htm
Nov 19, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
I need the service manual for the Aficio 220
hello there here is several links that will help you out ok
best regards michael
  1. RICOH AFICIO 220 Service Manual RICOH AFICIO 220 - It's a complete service manual, and it's in PDF format. ... i got my service manual for philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
  2. Ricoh Service Manuals - Copier Service Manuals Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Afico, AP, MLP, SLP, ... Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Aficio, AP, MLP, ...www.knowthesource.com/index.php?cPath=26 - 57k - Cached
  3. AFICIO 220 RICOH AFICIO 220 Owner's Manual ... for delivery information. Model: AFICIO 220. Type: Owner's Manual. Delivery: ... Manual received - Many thanks for an excellent service. Alain Fagan - 2006-04-11 ...www.manuals-in-pdf.com/55709-p-11284.html - 65k - Cached
Sep 14, 2009 | Office Equipment & Supplies
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
Hw many grams dv is needed in afficio 450 or gestetner 3245
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 220 - Connection with computer
Please use the link below and scroll down to choose your Operating system, and download and install the printer driver.
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=241&ricohmodelid=5&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fhtml%5Fre%2Fmodel%2Faf22%5F27%2Faf22%5F27en%2Ehtm
Hope you have a printer controller type 270 installed on your Aficio 220, already.
It can be connected with a parallel cable or ethernet cable if you have a network card installed in the printer controller of the Aficio 220.
Good luck and please rate me, thanks.
Jan 24, 2009 | Ricoh Aficio 220 Laser Printer
134 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
