My beko wm7247w wont spin
It will fill up with water but will not spin and timer wont count down. It will also drain. Cleaned out the filter and checked out the pump
  • Washing Mach... Master
  • 744 Answers
Hi Tina if your beko wm7247w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
    Genius:
  • 1,198 Answers
I saw lots of posts on Google about this machine. The timer is probably bad, maybe the fill sensor.
Posted on Nov 26, 2013
  • 76 Answers
SOURCE: wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Posted on Jul 07, 2007
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Posted on May 10, 2009
  • 574 Answers
SOURCE: I have a front loading GE wcvh6260fww that will
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Posted on Sep 03, 2009
  • 1937 Answers
SOURCE: my kenmore model 110 limited edition will fill
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Jan 04, 2010
Machine starts, fills with water & then nothing... clicks on and off & time counts down. Won't spin or drain water... have cleaned filter & removed pump to check it-- all good--- then worked for two loads...
YOUR ISSUE SEEMS TO INDICATE TO AREAS TO LOOK INTO THE NON WASH OR NO AGITATION USUALLY IS DUE TO A BAD WATER PRESSURE SWITCH, THE NO DRAIN NO SPIN IS USUALLY DUE TO A CLOGGED PUMPED OR IMPEEDED PROPELLER, ARE U SURE U CHECKED IT WELL? THE ONLY OTHER THING COULD BE IS UR CONTROL BOARD IS MIS COMMUNICATING WITH UR DRAIN PUMP?
SEE PICS
May 26, 2015 | Washing Machines
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My 8 month old beko wm6355w has a prob. it fills with water on all progs, counts down to get ready to wash, but doesnt start washing. Ive drained it, cleaned the filter (20p coin and a hair clip) but it...
8 months old- it is still under guarantee then?
Contact the vendor/Beko Service Helpline as soon as you can! It was good to check/clean the filter but do not do anything else which might invalidate the guarantee ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 25, 2011 | Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
I have a front loading GE wcvh6260fww that will fill with water, but will not agitate or spin out the water...thus, no washing of clothes regardless of cycle selected. The timer counts down and the water...
Sep 03, 2009 | GE WCVH6260FWW
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
hi
Apr 29, 2009 | Washing Machines
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
