Washing machine makes no sound - Washing Machines
My lg tromm washing machine makes squealing sound throughout the washing cycle
Good day,
for the sound of the washing machine may be have something inside the tub like metal or any. or the bearing of the tub is totally starting to worn-out, much better to call the service technician before to late, if the bearing problem and still using your machine some part will make problem also and its cost you a lot.
Nov 02, 2013 | Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
My washer whirlpool awm 258-1200 nordic makes bumping sounds
your machine and indeed every washing machine has a large cement brick on top of the drum inside if this gets loose or breaks it knocks the machine of balance causing the machine to make a bumping sound mostly when starting.adrian,,,,
Jun 28, 2010 | Washing Machines
Washing machine makes knocking sound
Hi, it sound like your machine overloaded, try smaller wash, and check to see if it does same thing, let me know, if it continues with small wash. good luck.
Aug 08, 2009 | Washing Machines
Washer making weird sound after filling
Check the belt and the motor, on the bottom of the washing machine. Also check the pulley for the tub and if all else fails then check the bearing in the drum and see if that has gone bad. Bt this sounds to be a motor issue either belt broken or motor is bad
Feb 11, 2009 | Kenmore Washing Machines
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
