Question about KitchenAid Refrigerators
KitchenAid KBFS25EWMS8 - Fridge cooling but freezer only cooling to 32 degrees. Also, fans are running constantly
    Genius:
  • 1,198 Answers
Sounds like low gas.
Posted on Nov 27, 2013
HVACRH20
  • 237 Answers
SOURCE: fridge freezer not cooling from new - buttons not working
Sounds like an air flow problem from the freezer section to the refer section. Check that nothing is blocking the air vents, and that the dampers are operating properly (they control the flow of air). Of course if it's under warranty... call the service techs out.
Posted on Nov 09, 2006
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
  • 833 Answers
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Posted on Nov 20, 2008
  • 2920 Answers
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Posted on Apr 24, 2009
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Compressor kicks on for five seconds then shuts off fan constantly running fridge and freezer not getting cool
Need complete model number of your refrigerator to help you better. Could be start relay, start capacitor or another problem, Thanks, Sea Breeze
Mar 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid KSRA22ILSS02 fridge won't get below 41 degrees
Try shut down for overnight and turn back on next day. I had same problem - cooling air duct was blocked by ice
Oct 08, 2008 | KitchenAid KSRA22ILSS Side by Side...
Refrigerators Logo
79 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
