Question about Video Game Consoles & Games
Fatal exit code detected: #440 -- packet is out of sequence
Ricoh sp 210su service call sc559 problem
Code
SC559
Description
Fusing Unit Third Jam Error (Fatal Error)
Causes
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
Remedy
• After this error has occurred three times, the machine will shut down automatically and cannot be re-started until the machine has been serviced by a service technician. • Check the paper transport path for any physical obstructions (paper scraps, etc.) • Make sure the fusing unit has been installed correctly • After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
Apr 10, 2018 | Office Equipment & Supplies
How can I correct error SC559?
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
Sc 440 ricoh 2045 Cod 440
Code 440 Description Main motor lock
A main motor lock signal is not detected within 2 seconds after the main motor turns on. Causes • Too much load on the drive mechanism • Main motor defective
May 17, 2015 | Ricoh Aficio Office Equipment & Supplies
Error Message PXE-MOF: Exiting Intel PXE ROM. what does this mean?
That means your hard disk is not being detected. PXE is a network boot, which is typically used in business environments. Check your BIOS settings and ensure your hard disk is being detected. If it is, make sure your boot order is set correctly. Network boot (PXE) should be set to the last item in the sequence. If the hard disk is properly being detected and an OS is present, you should never see PXE.
If your hard disk is not showing up, power your PC down (unplug the power) and check the cables to make sure they are seated.
Mar 17, 2013 | Acer TravelMate 5730-6204 Notebook
SYN packet for established connection
Check the "TCP end timeout" setting. You can find in Policy -> Global
Properties -> Stateful Inspestion. FW-1 will take a connection out of
its established connections table after two FIN packets (one from each
party) or a RST packet + the time defined in this setting.
Have a great day,
Bhautesh
Feb 18, 2010 | Nokia IP 440 Firewall
Fatal error message 13DOH
Per service manual, Parameter Chip failure
Data, which has been written, is read, checked, and
found faulty; rewriting of the data is then executed and
the data is checked to be found faulty during re-reading.
• A count value is found faulty during reading.
• Parameter Chip is detected to be not mounted during
initial mounting detecting sequence.
Did you recently have the firware updated? Or the main board has crashed. have service Technician reflash the software, or down load it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Aug 04, 2008 | Computers & Internet
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
