Question about Konka Televison & Video
The power light is disapeared and some times it flactuates
    Top Expert:
  • Konka Master
  • 75,386 Answers
Fluctuates means 'blinks'? How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 26, 2013
How it happen I don't know. 1. There is a horizontal line found on the middle of the window. 2. Many times window is flactuated and total window convert into white screen. At this time if I push or...
The connector that plugs in the LCD panel has got loose with time. You must open the lid of the laptop, access the LCD panel and reseat all connectors and contacts on it = no new parts needed.
Nov 02, 2010 | Computers & Internet
Saab 93 19 tid moving off in 1st gear very little power for a few seconds then car bursts into life same happens when changing up into 2nd gear
my saabturbo 93 year 2003 model,
sudenly abs and brake lights showing up at meter box... when the lights come out rpm meter, speedometer, air-cond all jam... if the light disapearred everyting will function well back.. on the same time i turn off enjin and try to start back but cannot start until the light showing.. when the light disapearred can start. why?
Oct 23, 2010 | Saab 9 3 Cars & Trucks
I am getting an engine system failure light coming out on my 2005 ford focus. The first day I checked oil and water. The oil was slightly low and I topped up. The water appeared to be overheating and I...
Sounds to me like you are having a cooling system problem, if water is boiling in the tank or radiator then the engine is overheating. If you have not flushed the cooling system, it would be a good idea to do so. Also you need to test the cooling system at idle and see if the engine will maintain normal temperature, without overheating. Overheating can be caused by plugged or restricted radiator, hoses, or the thermostat, also check the operation of the electric cooling fan. Once you solve the overheating you light should stay off. If you do not solve the overheating soon, the engine will suffer major damage, so check it out very soon. Hope this helps, let me know.
Aug 04, 2010 | 2000 Ford Focus
I have no power on my router. it just stopped. it tripped my mains power fuses. do i need a new power plug
pls check fuses inside box power section this is a common problem due to high voltage or power flactuating.
Jun 07, 2009 | NetGear RangeMax WPN824 Router
Power light not turning green just amber.not a power flactuation problem
There are a few things you will have to do. First, remove any newly installed card in the PCI socket if any. Try to re-sit the memory chip modules, that's removing and re-installing them. If they are two, try replacing one after another. Thirdly, try another VGA card incase you using the onboard one. Finally, swap your monitor. It must work. Good luck
May 26, 2009 | Dell OptiPlex GX260 PC Desktop
WHEN I TURN MY LAPTOP ON IT FLASHES 2-3 TIMES WHAT CAUSES THIS
perhaps some connected devices, turning on with little delay, and using (in a flash) power from the central unit.
it happens less frequently when windows is almost loaded, ( after the windows colored logo disapear or as it disapears)
Nov 22, 2008 | Gateway Computers & Internet
Televison & Video Logo
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
