Question about Hotpoint WMA64 Front Load Washer
Kenmore front load washer model 41744052400 will not enter into high speed spin at end of cycle. I can run the test for the different cycles and can get the high speed spin, but only in the test mode. Can pump be compromised and leaving water in the bellows so the washer wont enter into the high speed spin? Thanks for your time.
    Genius:
  • 1,198 Answers
Try to get the repair manual for your machine, it's worth the cost. Meanwhile, with the power unplugged, undo any wire connectors that just plug in and check for corrosion. Check the capacitor, a dent will ruin it.
Posted on Nov 26, 2013
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
barkencoa
  • 3463 Answers
SOURCE: Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
MrJuanDerful
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating. The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
  1. Putty knife
  2. Nut driver - I used a multi-purpose screwdriver without any heads attached.
Procedure:
  1. Unplug washer from the electrical outlet for safety
  2. Release two spring clips holding the front panel on: Insert a putty knife 5" in from the side between the top and the front panel. Pull the front panel forwards.
  3. Unscrew 2 screws holding the top down.
  4. Lift top - it's somewhat hinged in the rear with three tabs inserted in control panel.
  5. The little red tab at the end of the lid switch should be between the lip of the opening and the top; not sitting on top of the lip as mine was.  It's thin enough steel to push it with your bare hands.
  6. Make sure when the lid closes it actually causes the switch to turn on. You should hear a click.
  7. Put everthing back together. Plug washer back in. Put your tools away.
  8. Voilà. Done. Easy.  Even a woman or a ****** could do it.
Posted on Apr 26, 2009
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
  • 6 Answers
SOURCE: Test mode
press start once
then press start again now hold on/off and cancel together for a few secs should no say d/off or something should work now
Posted on Oct 17, 2009
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
Aug 14, 2014 | Frigidaire Washing Machines
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
