Gateway login - Computers & Internet
  • 27,725 Answers
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Posted on Nov 26, 2013
Forgot admin password for windows 7 starter on gateway lt400bu hav no disk or usb
When that happen, Igo and creating a new local account,
but you can fo to follow this link to try to fix that problem.
windows7 starter login screen password reset lost password login problems
Jun 07, 2017 | Gateway Computers & Internet
Bought a laptop at auction but don't have password to open up
Have a read.
How to Reset Forgotten Password on Gateway Laptop www.windowspasswordsrecovery.com > Resource > Password
A Gateway password is the password that you must enter to log into the administrator or user account on your Gateway laptop or ... You Forgot Gateway Laptop Password?
  • 4 Workable Ways to Recover Gateway Vista password www.windowspasswordsrecovery.com > ... > Windows Vista Password
    Lost Gateway Laptop password? ... 4 Workable Ways to Recover Gateway Vista password. ... you should login Gateway Desktop and enter User Accounts by clicking ...
  • How to Reset or recover the lost Gateway Laptop Windows ... www.windowsloginrecovery.com/reset-gateway-windows-7-password.html
    Forgot your Gateway laptop password? ... How To Get Gateway Windows 7 password reset or ... Reset Admin or other user account passwords with USB Flash ...
  • Gateway Official Site: Worldwide support.gateway.com/s/Mobile/Gateway/M320/3501937sp34.shtml
    Gateway.com Support. Select a country or region. Americas. Canada (English) Canada (Fran?ais) United States; Mexico; Argentina; Brasil; Colombia; Panama; Peru ...
  • Forgot Administrator Password for Your Gateway Computer ... www.top-password.com/knowledge/reset-gateway-password.html
    Forgot Windows login password for your Gateway computer? ... Forgot Windows 8 Password; Reset Windows 7 Password; Bypass Windows 7 Password; Windows Password ...
  • GATEWAY Bios Password, Unlock Your Laptop in minutes gateway-bios-password.biosremoval.com
    Here is the solution to unlock Gateway Bios Password, Gateway Password, Gateway user ... 2013, Gateway Bios Password, Gateway Password ... M320, M320S, M320X ...
  • How to Reset Gateway Laptop Password Windows 7 - Unlock ... www.youtube.com/watch?v=EUx5AjTCLFw
    • BY LYNDON MOSES
    • 3 MIN
    • 14K VIEWS
    • ADDED 2013-11-25
    Video embedded · How to Reset Gateway Laptop ... This may be the fastest way to recover a lost Windows 7 password that ... How to crack windows 7 "user login" password ...
  • Feb 11, 2016 | Gateway M320X Notebook
    Roku account login
    Sir
    I suggest you go to below link URL website for your Linksys Router connection check,if you connection is not set up the perform the step mention on Below URL link Below Website:
    http://kb.linksys.com/Linksys/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=b90128e4c5e547cc81cdcd13d42f1fc7_4755.xml
    Or
    Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
    Frequent wireless disconnection can be caused by different factors such as:
    i. Wireless interference within the network.
    ii. Wireless settings of the Linksys gateway are still set to default.
    iii. Firmware is corrupted.
    Reducing Wireless Interference
    If you are experiencing frequent disconnection from the wireless network, it will help if you check the following factors, all of which can greatly affect your wireless signals:
    2.4 GHz interference: Your gateway may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your gateway's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
    Physical obstructions: Your gateway or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
    Placement of the gateway: Linksys suggests that you place your gateway as high off the ground as possible. When placing the gateway in a high location, leave a distance of two feet between the gateway antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the gateway on the upper-most floor, and high up in the room.
    Surroundings: Keep the gateway away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
    Or
    In case you Still need Linksys online support assistance then follow us on for Linksys Router Support
    Mar 26, 2014 | Linksys Computers & Internet
    Forgot login pasword on gateway lt4010u
    If this is a Windows password, then you can ask local laptop tech to erase the password. Usually it cost $25 - $50. If this is a BIOS password, then you need to contact laptop manufacturer.
    Feb 18, 2014 | Gateway LT Series LT4010U Intel Atom N2600...
    Government gateway login
    try who.is
    type the site name
    the address is gateway for your login dialoug
    Nov 17, 2013 | Miscellaneous
    Gateway login
    Your description is too short to provide a meaningful answer to. Is it a Gateway PC, or a website called Gateway? Did you forget your password? What operating system is installed? Is it the Windows login or the BIOS login?
    Oct 19, 2013 | Computers & Internet
    Gateway login screen
    Restart the laptop, hit F8 repeatadly to start in safe mode. This will bypass XP's login screen. You can then manipulate the password in the control panel. Also, you can change it by going to commandprompt2.gif, type: net user * (your username) then whatever password you want.
    Oct 22, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
    Comtrend router: default gateway
    ok i see a few that you have left out :P try ending in 0.100 or 0.001 or 0.10
    Mar 16, 2009 | Comtrend CT-520 Router
    How do i change my gateway pass word
    login into the gateway via its address over the web browser ei.
    type for example lets say your gateway is 192.168.0.1 you type that into the browser, then it will ask for a password and user name some gateway uses blank password & username, some uses the name of gateway and password as the password, check you documentation will usually tell you what your user name and password are. once you login navigate to where your able to change username and password hope this helps.
    Jun 01, 2008 | Gateway Computers & Internet
    Computers & Internet Logo
    51 people viewed this question
    David Payne
    David Payne
