Question about Bose 3 2 1 GSX System
How to open the acoustimass - Bose 3 2 1 GSX System
  • 2,113 Answers
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
How do I open an Acoustimass 5 to clean it in hope this will fix volume problem.
They aren;'t meant to be opened. You have to force your way in. There's nothing likely to be faulty inside except if the main driver is blown and you can usually tell this without opening it. Check each channel on its own to see if you get bass on each.
Nov 06, 2009 | Bose Acoustimass 5 III System
No power to my speakers. How do you open the amp? BOSE acoustimass 5 Thanks
A powered AM5 bass unit? Undo the 1/2 screws, tease out the toothed quadrant by 90deg then tap the plastic panel down/away from the toothed quad. not easy the clips are usually very tight.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Stuck terminal tab
I was able to pry the stuck tab open with a small flat head screwdriver. After a number or repetitions of that process, plus some repeated pushing on the tabs, they started working normally.
Aug 05, 2008 | Bose Acoustimass 3 IV System
Bose acoustimass 15 series 1 channel loss
Sounds like you may have a blown output transistor or chip, which generally show no external signs of damage. This would take an experienced technician to find and fix, and I commend you for knowing to check the speakers, receiver and cables through substitution! If you're handy with a soldering iron and can find the parts, try replacing the output transistors or chips in question. These are what usually fail in audio power amplifiers - also check any power resistors for opens - some of them are designed to act as fuses to protect the more expensive components.
May 21, 2008 | Bose Acoustimass 15 System
Acoustimass 9
Acoustimass 10 IV cable
Feb 29, 2008 | Bose Acoustimass 15 System
Bose 3 2 1 GSX System Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
