Question about HP DesignJet 500ps InkJet Printer
22:10 printer error
Printer won't start
    Novelist:
  • HP Expert
  • 175 Answers
22:10 service station shutdown code
there is a cleaning wheel inside the service station which gets clogged up with dried ink, after a period of use the srvice station will gradually come to a stop and the motor will no longer be able to drive , thus throwing a 22:10 error
to repair - 1) order a new service station C7769-60374 and have it fitted - not forgetting the service staion calibration before using.
2) remove the current service station and strip and clear all waste ink- wash thoroughly and allow to dry- then refit, apply a thin layer if 3 in1 oil to the contact surface of the service station wheel. replace the unit and perform all service station calibrations,
if you would like a engineer for this job please call Belmonte on 0161 480 5556- we offer national uk cover and service plans as well as trade in's, trade up's and new sales.
Posted on Feb 12, 2014
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
I have a HP LaserJet 6040 with this error message 59.30
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
My printer won't print.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Sep 13, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
Error code PO3 is caused by Timing Disk dirty / damaged.
Please use this methods
1. Check the timing disk sensor located to the left of the printer
2. Check and clean the board.
And start to print... thanks
Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer won't print i got "E" on printer display color lamp blink check paper/check cartridge blink by the way i tried to change color cartridge as a solution but still got the same error
go to start then go to printer & fax right click on the printer look for pending job if you have pending job cancel all of it then wait till all job have removed
Aug 07, 2011 | Office Equipment & Supplies
Printer won't start. On computer, it says Error code 5200. On printer, it is flashing P08. What does this mean? Any advice?
This is a Print Head Overheating Error. You are probably printing a lot of photos all in one go and the head is overheating. Try again after it has cooled down and do not print so many pages all in one go. The P08 just means it stopped printing at page 8.
Jun 19, 2011 | Office Equipment & Supplies
HP 4500 won't print
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
Jun 12, 2011 | HP Office Equipment & Supplies
When I try to print I get an error and it won't print. The error message never shows up so I don't know what the error is. I have removed and reinstalled this printer 6 times now. I have rebooted...
Sounds to me like a bad USB cable,
Also when you're re-installing the printer are you using new/different drivers?
I would try a new cable and the latest drivers direct from Lexmark.com
Jun 01, 2011 | Lexmark X4650 InkJet Printer
Won't print - d5160 photosmart. system subspooler app error
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
HP DesignJet 500ps InkJet Printer Logo
221 people viewed this question
Seeker5211
Seeker5211
