Question about Dell 5130 laser scanner ros item inc
Dell 5130n Clean the ROS - Dell 5130 laser scanner ros item inc
Error 061-321 xerox workcentre 5024 - Xerox Office Equipment & Supplies
061-321 ROS Motor Fail
BSD-ON: CH6.5
The number of rotation of the ROS Motor did not come within the standard range within the specified time (5 s) after the ROS Motor On.
Cause/Action
1. Turn the power OFF and ON.
2. Check whether the Drum Cartridge is installed.
3. Check the ROS Motor (Output Check [061-001]) for operation failure.
4. Check the LD +5VDC power supply of the LD PWB J140 pin-8.
5. If no problem is found, replace the following parts in sequence:
• ROS Assembly (PL 2.1)
• ESS/MCU PWB (PL 18.3)
http://turbobit.net/upqkewkg8xjt.html
Feb 18, 2017 | Xerox Office Equipment & Supplies
What is a ROS system Failure
ROS stands for Raster Optical Scanner which is the scanner head/lense. This will need some cleaning from time to time depending on how much it is used. consult the printer manual on how to clean it.
Aug 06, 2014 | Xerox Office Equipment & Supplies
Fault codes 006-380
First check the Laser Unit for a lose connector.
6-380 ROS SOS Y Length
The interval of the ROS SOS (Y) signals exceeds the specified value.
Procedure
+5VDC is measured between the MCU PWB P/J401-B20 (+) and ground (-)
Y N
Replace the MCU PWB (PL 13.1).
Check the wire between the SOS PWB (Y) P/J516-1 and the MCU PWB P/J401 for an open
circuit.
Check the wire between the LD Drive (Y) J529 and the MCU PWB P/J401 for an open circuit.
If no problems are found, replace the ROS Assembly (PL 3.1).
If the problem continues, replace the MCU PWB (PL 13.1).
May 16, 2013 | Xerox DocuColor 3535 Copier
EPSON C1100 E 510 EROR
E510 idicate the ROS motor faulty... PWBA MCU could not receive signals output from SOS Sensor in ROS within the specified time.
Possible cause ROS assy, PWB MCU, Harness PWB, or LVPS..
but before you change any.. make sure all your cover are close properly..normally the fuser cover interlock switch can cause this error as well.. check the switch at the right side of the fuser cover...make sure it's not deform .
May 21, 2010 | Epson Aculaser C1100 Printer
Docucolor 12 printing nothing from glass
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Jan 19, 2009 | Xerox DocuColor 12 Color Copier
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Error code 11 phaser 7700 polygon motor failure
The polygon motor is part of the laser assembly, other wise know as the ROS, Raster Output Scanner.
It normally is not as simple as replacing the ros and moving on.
There are color registration adjustments to be done once the ROS is replaced. You can try contacting
https://www.partsdrop.com/store/
and seeing if they have one. That motor has the mirrors on it that rotate to focus the laser to the belt assembly.
Apr 24, 2008 | Office Equipment & Supplies
Error 10 laser unit failure on phaser 7700GX
That requires the replacement of either the ROS ( laser) assembly or the MCU board. I have seen both cause that code and indicate the laser has failed.
ROS is the laser assembly.
MCU board may not be detecting the ROS.
It is possible the connector that runs from the ROS to the board is loose, you may want to disconnect and reconnect that.
If the ROS is bad, you also have to have a laptop to connect to the machine to align the colors. That is called the regicon adjustment.
Modixerox 5510 functioning
Digital copiers will copy very light if the optics (mirrors, ccd lens) are dusty (opposite to the old analogue copiers which got darker) Clean whatever you can get at with a soft dry cloth.If it prints light from your computer then it won't be the optics, could be the ROS unit. If the ROS unit is dirty that's somewhat more complicated, the only bit you can get at is the ROS window, you'll have to pull the drum out and clean the glass window you can see from there
Jan 20, 2008 | Office Equipment & Supplies
Dell 5130 laser scanner ros item inc Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
