Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
HP m1522mfp printer repeats print when printing. The top line will repeat further down in a uniform pattern all the way down the printer. The toner does not smudge after print though
  • William Penduka
    William Penduka Nov 28, 2013
    It does the same thing whether i am printing from the P.C or doing a self test. The distance between the prints is uniform
  • HP Master
  • 1,679 Answers
This seems to be problem with Printer drivers. You have to uninstall and reinstall the Printer drivers.
Either do it from the Printer software disk or Download from the www.hp.com website.
Posted on Nov 26, 2013
maverick24
  • 56 Answers
SOURCE: Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Posted on Dec 03, 2007
  • 300 Answers
SOURCE: blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Posted on Sep 02, 2008
  • 66 Answers
SOURCE: Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Posted on Nov 07, 2008
SOURCE: hp laserjet 2420 printer printing completely black pages
remanufactured / compatible toner? sounds like defects to me. try OEM, or another supplier
Posted on Apr 05, 2009
Tualiapz
  • 80 Answers
SOURCE: printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
Posted on May 29, 2009
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
HP 2550 L ...When I try printing in color...........I get red/magenta spots on the printout........why is this happening ?
Are the spots in a uniform pattern? Try the Magenta toner cartridge first, the try replacing the imaging unit.
Jun 26, 2011 | HP LaserJet 2550L Printer
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
PRINTS BLACK HORIZONTAL LINE AT BOTTOM OF PAGE ON A M2727
Does this happen when you print or only when you use the scanner? I would test it by printing an internal page first. If the line is not there then chances are it's related to the scanner. Make sure the scanner is clean. If there is a line when printing the internal test sheet then then next question would be "does this line repeat, and if so, how often does it repeat?" That will give you an idea if it's the charge roller, toner or fuser.
Feb 25, 2010 | HP Laserjet M2727nf Multifunction Printer
Prints a line in a page
if that line is horizontal and repeat itself on the page then the problem should be from the Drum of Toner.(should be fixed if you replace Toner)
if it is vertical line all over the page then it ia allmost the fuser film (torn vertically) and if so you should send the printer to a specialized technician
Nov 26, 2009 | HP Office Equipment & Supplies
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
Shadows on prints
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
