Question about Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel
I left frozen container of homeade chili on the counter to thaw and forgot it overnight. it's now almost 68 degrees internal temperature. is it safe to eat?
The chili was in sealed plastic containers and left to thaw around 7pm. It was forgotten on the counter and is now fully thawed. It was sealed the whole time. I think it's ok but not sure.
  • 2,113 Answers
Once you reheat it thoroughly it is fine, but it is best to thaw in the fridge. The rule keep hot foods hot and cold foods cold can keep nasty bacteria at bay if it had gotten contaminated, but it was kept covered.
Posted on Nov 26, 2013
Testimonial: "Thank you!!"
Had a joint left over from party can i freeze it
Anything can be preserved by freezing but not everything is suitable for freezing because either the consistency of the food is destroyed or drastically changed by the freezing/thawing process or because the thawed food will not tolerate the thorough reheating that will be required to make it safe to eat.
Cooked, chilled foods that are perfectly fresh can be frozen and eaten after thawing with a fair degree of safety and such things as strawberries can be frozen even though they become a sort pulp after thawing.
Personally, I don't eat much from the freezer that hasn't been thoroughly heated/cooked right through...
Apr 10, 2016 | Grilling
How long to cook 6lb chicken?
Not frozen as mentioned in my last post to you. Take it now, and drop it into HOT water for 10 minutes. That will complete the thaw safely, as it will form part of the reheating to cook process. As I mentioned, I am a trade masterchef.
Regarding cooking, 20 minutes per pound so 3 hours.
Preheat oven to 450 degrees F (230 degrees C) and cook whole (thawed) chicken for 10-15 minutes. Then reduce the temperature to 350 degrees F (175 degrees C) and roast for 20 minutes per pound.
Feb 07, 2016 | Kitchen Appliances - Others
How do i deforst chicken breast
Put in ziplock bag. Submerge in cold water for about 1hour.
Dec 03, 2012 | Microwave Ovens
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Just need to know if the temperature should be higher to keep the room cool or lower...mine is in F and goes from 68 to 86 degrees F...Please advise if it should be lower at 68 degrees to keep the room at...
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
Jul 21, 2011 | Sunbeam Heating & Cooling
My wiper fluid is frozen in the pipes and the nozzles that lead to the actual spraying of the windshiled wiper fluid. How do I fix this the temperature is -20C
The only one way to fix this frozen windscreen washer fluid is to put the car inside a garage when the temperature is above 0 Celsius degree, (> + 5 C deg.), and wait for one hour for to thaw the car.
Nov 30, 2010 | 2006 Kia Sportage
Is there a way to thaw a frozen engine block?
hi,
stick a standard droplight with a 75 or 100 watt incandescent(regular) bulb under the cars engine, on the ground for a day or overnight.
jm
Jan 03, 2010 | 1997 Dodge Neon
Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel Logo
110 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
