Question about Clarion VX401
WON'T TURN ON
RADIO HAS POWER AND GROUND BUT WILL NOT TURN ON AT ALL
  • 47 Answers
Un hook the radio and harness. take the red and yellow wire and hook them together. take a jumper wire hook the ground and the red and yellow to a battery and see if it will turn on that way if not the you have a bad radio.
Posted on Dec 02, 2013
Saturn sl1 won't turn over when dome light and radio won't work
sounds like the rke module (Remote Keyless Entry) module losing power, I hope that helps you out
Nov 25, 2012 | 1998 Saturn SL
I changed the radio in my 97 monte carlo ls by hard wiring it in. radio works but when I have it on my speed guage won't work nore does my cruz control. When its off they work fine however my anti...
Yes it does you interuptted a power supply. You basically need to get another power B+ from a different source like the battery itself. Or a empty fuse slot. Becareful even with a common ground for cruise and speed gauge.
Feb 23, 2012 | 1997 Chevrolet Monte Carlo
My Pioneer DEH-P4200UB Won't power up in my 97 mustang gt. The car recently had a kenwood deck that we took out. we are still using the kenwoods wires. Help us lol
Hi
Please verify voltage at the constant (Yellow) wire With the ignition OFF
Then Turn the Key to ACC and verify voltage on the RED wire.
Double check the ground to chassis metal.
The radio should power on at this point if both power wires show 10-14.4VDC
If not - your radio needs repair.
Thanks!
Nov 02, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
How do I wire this radio into my boat? The wires coming out of the harness are one red accessory/switch, one black ground, one yellow constant power, and a blue power antenna.
Red goes to the battery.
Since this is a boat, the yellow will go to the battery too, but I recommend you put a toggle switch on this wire, so you can turn it off and it won't drain you battery. The black wire goes to the ground on your battery. The blue wire can be used as a remote turn on for an amplifier.
Thats' It.
Aug 31, 2011 | Car Audio & Video
My house lost it's ground when we had an electrical problem. Now my BOSE won't even turn on. Is there a reset button or a way I can get it to power up again?
when you lose your house ground/neutral connection,the system becomes a voltage divider type system between two appliances on each phase,and say a 1000watt appliance on one side and your bose on the other at say 20 watts,the lower wattage appliance will experience say a voltage of 170volts and the 1000watt will receive only about 60volts,you may have lucked out and only have blown an internal fuse or the radio could be shot
May 13, 2011 | Bose Wave Radio
Car wont turn over good battery no radio no nothing I have a 2008
look under hood remove cover for relays and fuses , should be a main fuse link where pos cable from battery and a ground come together with a fusible link in between it might need replacing
Jan 15, 2011 | 2005 Chrysler 300
Radio won't work put in aftermarket radio in won;t work why?
it it has power and ground, and it wont light up, its bad. Check and make sure you didnt blow a fuse.
Nov 27, 2010 | 2002 Ford Escape
Clarion VX401 Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
