Question about York Hardware & Accessories
Setting time on/off york timer ss721z
I had the timer working and then day light saving.... somehow timer doesn't seem to accept what I enter. I simpler set of direction with out the latitude and day lights saving info. just how to set for on at 6pm and off at 5am.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
The manual for the Tork SS721Z will walk you through the process.
Here is where you can find a copy of it in case you have lost yours:
http://www.generalfiles.biz/go/166153972200
Posted on Nov 27, 2013
jyackle5
  • 8197 Answers
SOURCE: intermatic timer T101
This link should help you set timer.
http://www.intermatic.com/images/instruction_sheets/T101.pdf
Good Luck and Please Rate FixYa!
Posted on Feb 27, 2009
gotgeek2
  • 565 Answers
SOURCE: Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Posted on May 03, 2009
protek480
  • 1714 Answers
SOURCE: York timer roblem
Grasp the timer dial with your fingers and pull out on it to turn. Set the time of day with arrow at bottom and release. That's it!
Posted on Jul 02, 2009
HVACjake
  • 22 Answers
SOURCE: I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Posted on Jan 21, 2010
SOURCE: Timer is set properly, but, the daytime lights never switch off
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 05, 2011
I have aMicromark MM9533 7day electronic timer (could be quite old), but cannot set it because I have lost my instructions. I can set the time ok, but when I try to set each day's on/off times, it...
There are eight timer on/off events, you set each of the on and off time pairs for a particular day of the week or combination of days. If it is that old, mine was bought in 1999 and just rediscovered, you should change the button battery found under the screw panel. The timer doesn't work the way you seem to be describing.
Sep 02, 2011 | Vacuums
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 25, 2011 | Hardware & Accessories
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DGM
DGM100 programming manual:
http://waterheatertimer.org/pdf/TORK.DGM100.INSTALL&OP.pdf
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
Explain in plain english how this works. Set time on face rotating dial clockwise.. push in pins to on and off positions. It seems to screwy unless timer runs counterclockwise, Set time at 5:30 AM amd go...
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Dec 04, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I programmed the timer to go on and off at a specific time and it doesn't work. The time of day and the date are working fine. It is only programmed for one light.
To program the ST01C:
http://waterheatertimer.org/ST01C-program.html
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual has troubleshooting. Since ST01C is battery operated, it will not work on loads farther than 100 feet away from timer. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with timer operation.
2) Solution:
a) Check for interference issues listed above.
b) Press MODE and make sure it is set to AUTO. If timer will not enter AUTO then no program has been set.
c) Re-check your programming as shown in step 6 of manual. Remember timer offers 40 programs. To set Program 1 >> 'on' time has to be entered and saved for Program 1 >>> and then 'off' time has to be entered and saved for Program 1. And then press MODE and set to AUTO.
Sep 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My Coralife aquarium lamp does not turn on once it is turned off.... until the next day. Other times it seems fine.
Dec 20, 2009 | Coralife Zilla Aqualight Power Center
Aug 07, 2009 | Coralife Zilla Aqualight Power Center
York timer roblem
Jun 15, 2009 | York / Cam-stat Compressor Cycle Timer...
I need the user guide for the time Tracker countdown timer
SET AUTO TIMER 1. Press and hold START and ENTER buttons at the same time for 3 seconds. 2. Press buttons until SET AUTO appears on the display. 3. Press ENTER. 4. Total Time: (Enter the total amount of time. It will automatically split between green, yellow and red lights). Use buttons to scroll through numbers and ENTER to accept. 5. Sound?: Do you want a sound effect at the start of the green light? 6. Yes/No: Use buttons to move cursor and ENTER to accept. 7. If yes, use buttons to scroll through sounds and ENTER to accept. 8. Repeat steps 7 and 8 for yellow and red sections. 9. Press MENU.
Feb 03, 2009 | Learning Resources Time Tracker Visual...
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Hardware & Accessories Logo
152 people viewed this question
Top York Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a York Hardware and Accessory Expert? Answer questions, earn points and help others
