Question about Bose Lifestyle 25 System
Only the sound from the radio works on my LS 25. Does anyone know how to fix it?
  • 34 Answers
Does the front display indicate that the CD is playing?If not,there's a fault in the power board.When this happens,only the radio will work,the CD mechanism will not be able to play.Connect an external audio source to the AUX input at the back of the player and test to see if there's sound.
Posted on Mar 11, 2014
Can you expand the freq. range of the cobra 25 CB 40 channel radio
Yes its possible to do with the EXPO kits.. or an eeprom. but beware of the FCC rules please. RX purposes' only not to be used for Transmiting..
May 05, 2013 | Cobra 25 LTD 40-Channel CB Radio
Trailblazer radio not working when cold
New one for me!! might be a ground issue with speakers ?? hope this helps and good luck.
Aug 15, 2012 | 2005 Chevrolet TrailBlazer LS
Do anyone know why is my radio still on when my car is off and with key being out.the car is 2001 lexus LS 430
the radio has 2 positions when "on" normal and key.if you press the on button when engine runs to turn on the radio it should go off when key removed...(its fitted so your passenger has music when your not in the car......key removed)
Jul 22, 2010 | 2001 Lexus LS 430
Ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
Aug 28, 2009 | Ranger Communications RCI-6900F-25 CB...
COBRA 25 LTD spikes without keying mike
buy a different cobra 25 4 pin mic and try that . If that doesn't work than you inherited a piece of junk .
Jul 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Subs on stock radio
chev stock radio does not have extra plug in for sub. to run your sub, im assumed you also going to run an amp to it also. there are no addition plug in in the back, but that does not stop anyone if you know how to rig things. i would not recommend rig wires on your 2007. I would install a new radio before rigging that car; than add a sub. keep in mind most of GM radios come with stock amp built into the radio itself. If you cut the wires from the radio and wire it to your sub amp you will get nothing but distorted sound. anything sound goes to any amp need to be pre-amp in order to work properly. hope that help some
May 16, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
Cb Radio blows the 15 amp fuse in the car when powered up
Look where the hook up wire goes into the circuit board. Find the protection diode.Round small black cynlinder with a silver band. cut the diode and run a continuity check across the positive and negative. If all checks out try to fire it up.15 amp fuse is way to high for that radio use 5- 7
Feb 09, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Radio locked 1991 lexus ls400
do you know how to reset radio code lexus ls 400 /1991
Aug 14, 2008 | 1991 Lexus LS 400
2008 Chevrolet Aveo Car Radio
remove the trim around the radio. that goes down to the cup holders. take it out by removing the screws. and wires
Jul 12, 2008 | 2005 Chevrolet Aveo
Bose Lifestyle 25 System Logo
76 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
