Question about GPS
What is this conduit used for - GPS
  • 2,113 Answers
Conduit is just a trojan or virus... it helps funnel other viruses to your computer... actually it acts as a conduit to put other viruses on your computer :)
Posted on Nov 26, 2013
How to drain Water away from window airconditioning? And how to install hose to drain water from window airconditioning?
with window air conditions there is an attachment that you can get that allows for a hose attachment
failing that use pieces of 25 mm (1") conduit . start with a right angle silastic it against the drain hole and short pieces and other angles to get the conduit to where it drains into a garden of water drain.
e conduit saddle clams to hold the conduit in place.
May 11, 2015 | Cars & Trucks
Conduit ******
Conduits generally are associated with malware or viruses.
I use Norton 360 and Malwarebytes.
Apr 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I want to totally remove conduit from my computer.
Removing conduit totally can be pretty hectic as it has a footprint in lot of different locations on the system. I suggest you to perform the following steps
Step 1 - Uninstall the Conduit Toolbar
Step 2 - Delete Conduit Folders, Files and Gifs from hard drive
Step 3 - Delete Conduit Registry Keys:
· Click on Start Button > Run > Regedit
· Next, click on Menu Bar > Find > Conduit > (select, keys, value and data) > click the Find Button
· If keys are found, then from inside the right hand panel right click on the sub-key, select modify and erase the value/data, then click OK
Step 4 - Delete Conduit from Browsing History
Step 5 - Remove Conduit Cookie
For further information and how to carry on these steps refer to this article: http://pcsmarties.wordpress.com/methods-to-remove-conduit/
Sep 24, 2013 | Google Chrome
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
Remove conduit toolbar
The Conduit Toolbar is a custom search toolbar that allows you to search for content such as pictures, videos, research and services on the Internet.
A customized Conduit Toolbar can be branded with a business logo and include your favorite links and search engines.
If you do not use it, removing a customized Conduit Toolbar is like removing any other program through the Windows operating system.
Click "Start" and select "Control Panel."
Click the "Uninstall a Program" link under the Programs section.
Select "Conduit Toolbar" from the list of currently installed programs, and click "Uninstall."
Click "Yes" to confirm your choice.
If you are using Mozilla Firefox, click the "Firefox" menu, select "Add-Ons" and choose the "Extensions" tab.
Click "Conduit Toolbar" and select "Remove."
Restart your Web browser.
May 06, 2013 | Computers & Internet
CONDUIT CHROME CRASHES COMPUTER
Remove the toolbar
The Conduit Toolbar is a custom search toolbar that allows you to search for content such as pictures, videos, research and services on the Internet. A customized Conduit Toolbar can be branded with a business logo and include your favorite links and search engines. If you do not use it, removing a customized Conduit Toolbar is like removing any other program through the Windows operating system.
Click "Start" and select "Control Panel." Click the "Uninstall a Program" link under the Programs section. Select "Conduit Toolbar" from the list of currently installed programs, and click "Uninstall." Click "Yes" to confirm your choice. If you are using Mozilla Firefox, click the "Firefox" menu, select "Add-Ons" and choose the "Extensions" tab. Click "Conduit Toolbar" and select "Remove." Restart your Web browser.
Dec 20, 2012 | Computers & Internet
How to put steering wheel back on
Are you talking about the spring and C-clip that go on the steering shaft UNDER the steering wheel? There is a special tool required to do that. However, I MADE a tool to accomplish this task by using a short piece of electrical conduit that was jus large enough in diameter to slide down over the steering shaft. (I think it is 5/8" conduit - can't get to my tool box right now to check) Anyway, measure the diistance from the end of the shaft to the groove where the C-clip snaps in. Cut a piece of conduit to this length. Then put your spring on and slide the C-clip on as far as you can by hand. Then put the piece of conduit over the shaft so it is contacting the the C-clip. Then use a flat-washer on top of the conduit and insert your steering wheel fastening bolt into the washer/conduit apparatus and screw it into the shaft. The bolt and washer will push the conduit, which will force the C-clip to slide down the shaft and compress the spring. When you screw it far enough, you will hear the C-clip "Click" into the groove. Voila! your spring and C-clip is installed. Unscrew the bolt and remove the conduit and washer, then assemble the rest of your steering column/steering wheel components.
Dec 24, 2011 | 1995 Ford F150 Styleside Regular Cab
I need to stand 2 poles up on either side of my yard for Christmas I plan to run lights down from the top and I need to support the pole for all of winter it will be about 7-9ft and I will have 16 strands...
A 10 foot stick of 1 1/4" or so of electrical EMT conduit would probably work:
http://www.homedepot.com/Electrical-Electrical-Boxes-Conduit-Fittings-Conduit/h_d1/N-5yc1vZ1xg4Zbohl/R-202068042/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
The conduit is easily driven into the ground using water. Just pour some water on the ground and start working the conduit up and down in the same spot, add more water as needed until the conduit is in the ground 2 or 3 feet.
Purchase one 1 1/4" EMT connector to fit on the top end of the conduit. That connector can be screwed into a 1 1/4" galvanized floor flange from the plumbing dept.
http://www.homedepot.com/Plumbing-Pipes-Fittings-Valves-Galvanized-Pipe-Fittings-Fittings/h_d1/N-5yc1vZ1xg4Zbuue/R-100183709/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Drill the (1/4"dia. or so) 16 holes around the perimeter of the flange for each strand. Maleable iron is easy to drill.
The conduit should be fairly secure by itself but you could use small diameter steel guy wire (14 ga. or so) and some tent stakes for added support. 4 should be enough.
Nov 13, 2010 | Home
GLD6200 NOISY
The sound is almost always caused by a worn docking cone “O” ring on the main conduit. When the docking cone “O” ring wears, the mid level spray arm conduit is no longer constrained and it can vibrate against the docking cone, making the “growling” or vibrating sound. Use a plastic wire tie to quickly verify if the growling noise is coming from a worn “O” ring. Snug the mid
spray arm coundit against the upper rack with the plastic wire tie. Run the dishwasher. If the noise goes away, you have verified the presence of a worn “O” ring. Remove the wire tie when the test is completed.
The recommended repair for this problem is to replace the WD12X10059 (titanium) or WD12X10121 (grey) docking cone. These parts supercede to the full main conduit. It is not necessary to replace the full main conduit for this problem. Remove the docking cones from both the existing and new main conduits. Install the docking cone removed from the new
main conduit on the existing conduit still installed in the dishwasher.
Oct 25, 2007 | GE 24 in. GLD6200L Built-in Dishwasher
Switch from outlook to palm desktop
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck. Support Knowledge Library Click here to go back Click here to print Solution ID: 25263 Switching between Outlook and Palm Desktop synchronization Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device. What do you want to learn about? * Switching synchronization: Palm Outlook Conduits * Switching synchronization: PocketMirror Conduits * Synchronizing partially with Palm Desktop, partially with Outlook * Note about data transfer * Macintosh information * Multiple users on the same desktop computer Switching synchronization: Palm Outlook Conduits These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process. If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld. 1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM. 2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have) 3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook. 4. See our note about data transfer Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
GPS Logo
21 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
