Question about Bush Televison & Video
HDMI input doesn't work
My son uses the TV primarily for his xbox (via HDMI) but after seconds the screen goes Pink/Purple fuzzy and sound is all white noise. Tried new cable - same again. problem not repeatable using xbox on any other television in the house. Also, the iPod dock doesn't work any more.
    Master:
  • Bush Master
  • 688 Answers
Replace Main PCB (it has the I/O ports & circuitry on it)
Posted on Nov 30, 2013
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
SOURCE: HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Posted on Dec 08, 2008
gage8405
  • 5 Answers
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
SOURCE: Insignia 42" black screen and line problem
either call the warranty or get a new t.v.
Posted on Mar 04, 2010
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
Insignia 42 lcd hdtv purple pink screen
If DVD input works likely a issue with the signal.
If using a cable or sat box or even a receiver inline--unplug each and after several minutes plug back up to allow each unit to try to reboot.
If using component connections from box or receiver they may be the issue or not. In that case if a box is feeding signal via component or even HDMI the box (if reboot does not fix this) may be bad.
Another simple test if cable is used with a box is disconnect cable going to the box and connect directly to set--that way you will know if box is or is not the problem.
May 22, 2012 | Insignia 42" LCD Flat-Panel HDTV
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
What is up with my 360 when ever i play it for about 30min it shows green fuzzy lines down the screen of my tv and purple fuzzy lines down my tv screen and after those two happen sometimes it will have red...
well definitely video issues of some sort. if you have a second video cable (or hdmi cable if your unit supports that) give that a try.
*assuming that doesn't work Unfortunately it sounds more likely that it's an issue with the video card inside the xbox. this may be repairable by a professional.
if you have it under warranty i would contact microsoft for a replacement/repair https://myservice.xbox.com/en-US/Pages/Welcome.aspx or call Toll free: (800) 4MY-XBOX
~best of luck!
Mar 13, 2011 | Microsoft Xbox 360 Console
My xbox 360 wont work with an hdmi cable all i get is sound and the screen just says unsupport
that normally means that the TV doesn't support the software version...need to contact either the tv makers support number, or Xbox.com/support, and explain your problem.... maybe there is a setting on your TV that can change the setting for your hdmi input
Feb 26, 2011 | Microsoft Xbox 360 Console
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
XBOX Live plays back with pink hue
*YOU DO NOT NEED TO SWITCH TO STANDARD DEFINITION*
To view the videos via HDMI, you need to switch the HDMI Color Space setting to "RGB". To do this go through:
My Xbox > System Settings > Console Settings > Display > HDMI Color Space > and from there select RGB
I had this same issue when watching movies from a USB flash drive and this worked perfect, so I hope this helps those of you who love your HDMI as much as I do.
Aug 17, 2009 | Microsoft Xbox 360 Console
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
Green screen via analog connections
check if your input settings in the RXV663 for the S-video and composite are correct. Both connections are about the worst possibilities for video signal. What might help is powering of all other equipment not used when using XBOX or VCR, really powering off, not leave in standby.
Does your TV support analogue inputs? Than use them for the XBOX and VCR to connect directly to your TV for video, sound can still be connected to the yamaha.
let me know if it works.
Aug 08, 2008 | Yamaha RX-V663 Receiver
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
