Question about Acer AL1716 17" LCD Monitor
Is this a problem?
I recently got myself a new PC which includes an Acer AL1716 monitor.I think its a brilliant monitor in terms of performance and the price.But being a perfectionist I am easily irritated even by the slightest of glitches.Well, a few days ago my computer hung while trying to run a game with extremely heavy graphics due to which I had to manually turn it off.On restarting I let Windows  check the file system for errors and it found none.Now I have started noticing a black vertical line at the right border of my monitor.Well I'm sure most people won't notice it because it is quite narrow(less than a cm maybe).But there is a similar line on the left side that is slightly thinner.Adjusting the settings has not helped.I'm not even sure if this line was there before I manually restarted the computer.But its bothering me! I hope there is nothing wrong with my monitor.Please reply.
    Novelist:
  • 103 Answers
Hi Viv,
Hope this will give you hints. If you haven't noticed first day you bought and used it with this negligible glitches you mentioned. There are factors to test and consider; try adjusting resolution frequencies (lower to higher) select Apply settings if you noticed been good; color/scheme modes of your video card driver/application software. I have met this kind of problem by fine tuning the video card settings and even replacing the video card not common it monitor problem. However if you noticed and doubtful even, get a change to dropby to the store you bought it let them check the unit. If the output still considerable, you still can use and we'll wait and see if it getting worse before the warranty period.
Best regards,
Rosener
Posted on Jan 30, 2008
I used to use viewsonic 17inch monitor and the color was perfect. Recently i change to acer AL1716, but there is no red color. How to fix the color setting problem? thanks
Generally, this is due to a loose or bad cable. Unplug, and replug your video cable one both sides. If that doesn't work, then use a different cable. If that doesn't work, contact Acer to see about a warranty replacement.
Mar 09, 2011 | Acer AL1716 17" LCD Monitor
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Acer AL1716 17" LCD Monitor
Hi, My Acer AL1716 monitor has stopped working and the light on it just keeps flashing. I have put a new power cable on it but still the same problem. I have plugged it into another PC and it still is not...
More likely to have capacitors failure in the power supply section, that will be the first place to check, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside when you open it up so we can guide you further.
Mar 26, 2010 | Acer AL1716 17" LCD Monitor
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
There is no indication of power to the monitor. I
You need to check the caps in the power supply section, please see my pictures here so you know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
Feb 19, 2010 | Acer AL1716 17" LCD Monitor
While working on PC der was spark at plug point and now monitor is not turning on.
u need to either change the power cable of the monitor or go for a repair of the LCD.
the power cable may have been spoilt most probably,use earthed sockets for ur PC and check lose connections.
i myself had experienced this problem earlier due to improper earthing
Jan 13, 2010 | Acer AL1716 17" LCD Monitor
Where can I find a replacement bulb for my monitor?
have you tried the manufacters website or ebay?
Feb 27, 2009 | Acer AL1716 17" LCD Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Flickers and shows acer logo
Perform a system recovery:
2 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Alt/F10 during boot right after Acer splash screeen on startup
http://us.acer.com/public/page11.do?sp=page74&UserCtxParam=0&GroupCtxParam=0&dctx1=25&CountryISOCtxParam=US&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+States&crc=790373818
Oct 26, 2007 | Acer AL1716 17" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
