Question about Samsung DV218AEW Electric Dryer
Makes a grinding noise when i turn it on
At first the lent catcher would not close then finally got that fixed, it started making a grinding noise when I turned it on.
    Genius:
  • 1,198 Answers
The lint screen may be too long, is it the original part? With all the fussing around, the screen holder may have gotten knocked out of place. Probably going to have to open the machine to get things straight.
Posted on Nov 26, 2013
2 Suggested Answers
  • 949 Answers
SOURCE: Hello I have a Samsung dryer model # DV337.Today I
When you pulled the lint filter something may have fallen into the blower which is just below the filter. Use a flashlight to try and see down the chute, if you cant find what is stuck there, you may need to call for service to disassemble the dryer to remove the object so it does not destroy the blower.
Posted on Apr 19, 2010
Frigidaire frqe7000lw vibrating grinding
did you leave your lent filter out a couple of times? Sock or lent wad may be caught up in the fan that forces air through the dryer.
APPLIANCE 911
Oct 13, 2015 | Frigidaire FRQE7000LW Electric 7.0 cu ft...
Grinding sound
You need to make a thorough inspection for debris and pet hair cloggin your vac. Could have ingested a load of kitty litter or....
Jan 20, 2013 | Bissell 1622 Powerlifter Powerbrush...
Dryer started making a loud noise when u start it its leveled and there is no lent in the dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 20, 2011 | Crosley Dryers
Something fell in side the lent catcher on my kenmore 70 series dryer and now its making a very loud noise how can i take it out
Was it metal? Attach a small magnet on a thin stick or string and pull the thing out. Not metal? Something else to attach an object: sticky tape, wire hook.
No luck? Call Sears and ask their repair department for instructions.
Or call Kenmore customer service for advice.
Jan 23, 2011 | Dryers
Starter makes a grinding noise. and wont start changed starter and have the same problem. changed crank position senser and it worked for a while. changed it again but didnt fix the problem.
if the starter is making a grinding noise when you turn the key, it's one of several possiblites. 1. Bad Starter. 2. Bad flywheel. 3. You need starter shims that fit between the starter and the motor. Most starters will bolt straight up but sometimes the gears get too close so you need to shim them apart.
May 30, 2010 | GMC K1500 Cars & Trucks
Are the following parts available? A lent catcher and the plastic cover for the lent catcher for model 78415820.
I;m sure you can get them replaced at ur local appliance store,and first try there junk pole for a model just like urs/
Oct 02, 2009 | Kenmore Dryers
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Grinding noise from hell - no spin, no agitation (except my own!).
Please see the following link for all possible troubleshooting tips:
http://www.repairclinic.com/0088_11_1.asp#Level1_3
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Washing Machines
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Samsung DV218AEW Electric Dryer Logo
103 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
