Question about Diesel Watches
DZ1321 Battery problems
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
My fossil big tick has stopped working
Lots of possibilities. One is they put in a dead battery, don't laugh. I have seen this several times. Two, the watch has a problem other than the battery and you assumed the problem was the battery when actually it is something else. I have more but these two are the obvious. Find a watchmaker.
Oct 06, 2012 | Fossil BQ9177 Wrist Watch
I'm from India and I have an Relic (Bought from US) the same model but in silver color. Its been almost two years and it is stopped. Whether battery needs to be changed or anyother problem? If I want to...
Most probably its battery problem. You can go to any reputed (Titan, Timex) watch showroom and get its battery replaced. They will change the battery immediately.
Don't get the battery replaced from the small watch repair shops. They don't have original batteries, so your battery will not last long.
Hope it helps. Don't forget to rate me. Thanks for using FixYa.
Jan 14, 2011 | Relic Goldtone Large Link Goldtone Watch...
Battery and light problem
mcdevito75 here, If you have a warantee from the place that changed the battery, return the watch to them siteing this problem, If no warantee then you are on your own and may have even though it's new a weak battery. Viisit the repair service directory rite here at fixya, bottom of pge click on repair service directory then watches.
Jun 27, 2010 | Suunto 51-StingerSTD Wrist Watch
My freestyle model 798 is contantly resetting itself back to Jan. 1 12 am. Is this a battery problem?
No, this is not a battery problem. Use your users manual and read how to reset time and date.
Jan 12, 2010 | Freestyle Watches
My Timex is 10 years old or more, it has LCD Hands. What is this model called? How do I get it working?
First step should be battery change. Get the old battery out of watch, read all the writings on battery and buy exactly the same one. Fit new battery back in watch and check if it's working.
If problems persist, submit make, model and all writings on caseback, explaining the problem.
Rate me, please.
Aug 14, 2009 | Timex Watches
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Sep 09, 2008 | Watches
Timex expedition problem
You probibly need to have the anologe serviced. It isn't like the old days when watches had a mainspring which, when you wound it the gears would push by anything that got in the gears way because of the pressure form the mainspring. Now with quartz watche ANY little thing ( dust sooo small) will stop the gears from running. I would take the watch to a reputable watchrepair and have them check the battery. DO NOT ask them to sell you a new battery just CHECK it. If you get a new battery, it the watch probibly will run good again for about 3 weeks , and then start acting up again, because a new battery might have enough power (at first) to get by the watches problem untill it uses some energy up. But if your battery is bad that to could cause this , but that is highly doubtful that is the problem.
If you still have a problems please let me know I will be glad to assist you!
Aug 18, 2008 | Timex Expedition 84601 Wristwatch
Changed the battery in my fossil watch series AM-3692. The watch will not work now. Battery is the same number and manufacturer that was in the watch originally.
You may have thought your battery was bad, when in reality the watch had a problem to began with. You also may have bought a dud battery. Have the battery tested, if good you either have a mechanical problem ( there is something stopping the gears from moving) or you have a electrical problem ( the curcit board or coil is shot). Fossil has a 11 year warranty on most of their watches, and even if you don't have your original reciept, I would get ahold of them and ask what they can do for you. Or you can take it to a watch repairman to repair but it will cost you.
Aug 04, 2008 | Fossil Watches
Watches Logo
21 people viewed this question
Top Diesel Watches Experts
Ansel Alberto
Ansel Alberto
randymanfive
Are you a Diesel Watch Expert? Answer questions, earn points and help others
