Question about Amana ABB1927DE Bottom Freezer Refrigerator
Fridge problems Freezer not affected
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
The freezer works fine; the refrigerator isn't cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2011 | Refrigerators
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
May 26, 2011 | Frigidaire Refrigerators
Freezer works fine but the refigerator does not get cool
Oct 11, 2010 | Frigidaire FRT17G4B Top Freezer...
Refrigerator will not cool but freezer works
Oct 11, 2010 | Kenmore Refrigerators
Sxs fridge freezer is cold but fridge not
Aug 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge wont get cool
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
Jul 03, 2009 | Refrigerators
Fridge freezer not working
1/ defective compressor
2/ refrigerant leak
Possibly defective thermostat / sensor but unlikely since both your fridge and freezer are affected and there are two seperate thermostats
May 01, 2009 | Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
14 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
