Question about LG 30" Built-In Electric Induction Cooktop - Black
Er22 appears on hob
Er 22 appears on hob
Error code er22 is showing, any ideas?
Google search your manufacturer make and model and the words error code 22. You can find your answer in the search results.
May 02, 2015 | Cooktops
How to un lock
My hob unlocks with that I turn on the hob and the the L appears, then I hold down the lock button until it disappears then I push the STOP/GO button.
Jan 22, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Hob not working
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
LG 30" Built-In Electric Induction Cooktop - Black Logo
20 people viewed this question
Top LG Cooktops Experts
cwradio73
Dave Lammas
Level 1 Expert
Dan Apthorp
Are you a LG Cooktop Expert? Answer questions, earn points and help others
