Question about GE Profile JTP18 Electric Single Oven
Ge oven makes clicking sound - GE Profile JTP18 Electric Single Oven
GE j TP 86 oven wont heat
sounds like the hi-limit switch
Mar 02, 2013 | GE JTP86 Electric Double Oven
Microwave oven noise
Take it back to the dealer and enquire if this is normal. If it isnt, then exchange it for another and check in the store itself, before you take it home. If it is normal, then you have nothing to worry about :)
Sep 26, 2008 | Ovens
GE Profile JCKP18BW-1 Built-in Oven/Convection fan clicking
how to reset electronic
GE PROFILE jckp18bw
Thanks
Dec 27, 2012 | Ovens
Neither oven will heat when start is pressed, get a clicking sound from panel, temp stays at 100 deg.
Check for 220v as 110v will give one leg of power but not both. your breaker. or your control board is faulty.
Sep 03, 2012 | GE JKP45 Electric Double Oven
How can I obtain a manual for this oven-GE JT952SOK2SS
Click this link to obtain your manual http://www.managemylife.com/mmh/owner_manuals/4884/GE-Built-In-Oven-Electric-L0502248?brand_name_search=JT952SK2SS if you have any further questions or are unable to obtain your manual through this link message me back and Thanks again for using Fixya
Rick
p.s by clicking this link you will be able to download your manual for free just click where it says download above the document where it says click here to download Thanks again
Jun 01, 2011 | GE Profile JT952 Electric Double Oven
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
GE Profile JTP18 Electric Single Oven Logo
42 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
