Question about Dell Dimension 3100 PC Desktop
A03 checkpoint changing bios a04 to a06
  • 115 Answers
Make sure that there is no power failure during bios update and you have a power back up of atleast 10-15 minutes. Download the update from Dell's website and double click on the .exe program. Wait for program to finish the job.
Posted on Nov 26, 2013
2 Suggested Answers
  • 51 Answers
SOURCE: my dell dimension 8400 bios a03 fails to bootup
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Posted on Mar 10, 2009
Tip
How to Downgrade BIOS from A06 to A04
I spent a few hours researching how to do this. It was not easy and I had a few false starts.
Aside from downloading the patch and making a DOS boot disk from a USB drive, there are a few pitfalls you want to avoid. They are all documented in this blogpost. Enjoy!
on Dec 23, 2009 | Dell Inspiron Mini 10v Netbook Computer
TOSHIBA SATELLITE l.305 6050A2170401-MB-A03 NEED INSTALLATION GUIDE/HOW TO CLEAR CMOS UNABLE TO BOOT/RESET BIOS CLOCK
well this is not too much difficult ...1) go to bios and reset factory defaults ( i believe u know how to get access in bios ) 2) unassemble your mother board ... you will find a battery ( which we technicians call cmos battery) ..remove it and then insert it ( take 2 mint break)...
Jan 28, 2013 | Computers & Internet
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
JV AV36890 TV. My young daughter pressed buttons and managed to switch it from channels in the "A" set (ie A02, A03, A04...) to the B set- which has resulted in fuss and noise. Even the menu...
On your remote, push the input button, to change the input back to A. If that don't work, then unplug your set from the wall for 40min, and that will reset it back to normal.
Nov 22, 2010 | JVC AV-36890 36" TV
Sudden power off of Dell Studio 1558
Check the BIOS for PC Health settings. It is possible that you have put a low value for "Critical Temperature", which makes the Laptop to turn off.
Mar 04, 2010 | Dell Studio 15 Laptop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Optiplex 560 Power Intermittent
Try updating the BIOS. Seems there were some advanced power management improvements.
Dell Downloads
The following changes were made to the A04 BIOS for the A06 BIOS: 1) APM issues device commands in SMM. 2) Fixed APM to issue power up/down commands to peripherals in SMM. 3) Turbo/Deturbo switching done in SMM. 4) Implemented <\> Turbo/Deturbo hot key. 5) Password checked after exiting Setup and before OS booting. 6) Fixed the problem with #9 GXE64 Video card losing its video at the end of POST. 7) Fixed the problem with WINICU having General Protection Failures. 8) Fixed the problem with Real Time Clock not being updated correctly when in Power Managed mode.
May 15, 2008 | Dell OptiPlex GX260 PC Desktop
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Dell Dimension 3100 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
