Question about Xerox Office Equipment & Supplies
134-211 how to fix dis - Xerox Office Equipment & Supplies
How to fix a shorted out condenser and points in a79 mgd dis.
the movable arm of the points has to be insulated from the mounting post and plate underneath
it is common if you are not careful for the terminal of the condenser to touch the base plate as you tighten up the nut of the bolt
Oct 02, 2016 | Cars & Trucks
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
How fix a sharp mini component system cd es 777 with no sound and won't turn on
i have dis sharp compnent when i turn it on the dis-lay shutoff
May 28, 2013 | Audio Players & Recorders
Error 0x80040702 comes up referring to GameuxInstallHelper.dll problem on trying to uninstall FSX
i fixed dis way.
-first remove it from ur computer.
-den place the gameuxhelper.dll in the folder ur goin to install it(but put it before installing it) the link- http://www.dlldump.com/download-dll-files_new.php/dllfiles/G/GameuxInstallHelper.dll/1.00.000.0000b/download.html
after place dis into the folder install.
Apr 22, 2011 | Microsoft Flight Simulator X for Windows
Hey there,i have a 1991 msuatng LX with the 2.3L ho engine running an 8 plug head. it sounds like i may have a misfire of some sort or my timing may be out but im not sure how to tell, could someone give...
Insert each wire on the proper terminal of the ignition coil. Ensure that the coil boots are fully seated and both locking tabs are engaged. The terminals are identified on the ignition coils. Install wires as shown in the illustration. The 2.3L firing order is 1-3-4-2 for both ignition coil assemblies.
Distributorless Ignition System In the distributorless ignition system (DIS), all engine timing and spark distribution is handled electronically with no moving parts. This system has fewer parts that require replacement and provides a more accurately timed spark. During basic operation, the EEC-IV determines the ignition timing required by the engine and a DIS module determines which ignition coil to fire.
Components
The distributorless ignition system (DIS) for the 2.3L twin spark plug engine consists of the following components:
  • Crankshaft timing sensor
  • DIS module
  • Two ignition coil packs
  • Spark angle portion of EEC-IV
Crankshaft Timing Sensor
The crankshaft timing sensor is a dual hall effect magnetic switch, which is actuated by the dual vane cup on the crankshaft pulley hub assembly. This sensor generates two separate signals, PIP (profile ignition pick-up) and CID (cylinder identification). The PIP signal provides base timing and RPM information, while the CID signal is used to synchronize the ignition coils. Initial timing (base timing) is set at 10 degrees BTDC and is not adjustable. Ignition Coil Packs
Two ignition coil packs are used for the 2.3L dual plug engine. The two ignition coil packs are triggered by the DIS module and are timed by the EEC-IV. Each coil pack contains two separate ignition coils for a total of four ignition coils. Each ignition coil fires two spark plugs simultaneously, one spark plug on the compression stroke and one on the exhaust stroke. The spark plug fired on the exhaust stroke uses very little of the ignition coils, stored energy, and the majority of the ignition coils, energy is used by the spark plug on the compression stroke. Since these two spark plugs are connected in series, the firing voltage of one spark plug will be negative with respect to ground, while the other will be positive with respect to ground. Refer to thePowertrain Control/Emissions Diagnosis Manual for additional information on spark plug polarity. DIS Module
The main function of the DIS module is to switch between ignition coils and trigger the coils to spark. The DIS ignition module receives the PIP and CID signals from the crankshaft timing sensor, and the SPOUT (spark out) signal from the EEC-IV module. During normal operation, PIP is passed on to the EEC-IV module and provides base timing and RPM information. The CID signal provides the DIS ignition module with the information required to switch between the coils for cylinders 1 and 4 and the coils for cylinders 2 and 3. The SPOUT signal (from the EEC-IV) contains the optimum spark timing and dwell time information. The dwell time is controlled or varied by varying the duty cycle (duration) of the SPOUT signal. This feature is called CCD (computer controlled dwell). Therefore, with the proper inputs of PIP, CID and SPOUT the DIS ignition module turns the ignition coils on and off in the proper sequence for spark control. CID is also sent to the EEC-IV micro-processor to allow for Bank to Bank fuel control. Failure Mode Effects Management
During some DIS system faults, the Failure Mode Effects Management (FMEM) portion of the DIS ignition module will maintain vehicle operation. If the DIS ignition module does not receive the SPOUT input, it will automatically turn the ignition coils on and off using the PIP signal. However, this will result in fixed spark timing (ten degrees BTDC) and a fixed dwell time (no CCD). If the DIS ignition module does not receive the CID input during engine cranking, random coil synchronization will be attempted by the module. Therefore, several start attempts (cycling the ignition from OFF to START) may be required to start the engine. If the DIS module loses CID input while engine is running, the module will remember the proper firing sequence and continue to fire to maintain engine operation. Dual Plug Inhibit
Dual Plug Inhibit (DPI) is a function of the EEC-IV that is only used when the vehicle is being started at temperatures -7° C (20° F) and below. During engine cranking, the EEC-IV will only fire the spark plugs on the right hand side of the engine. When the engine has started, the EEC-IV will send a signal to the DIS module to start normal dual plug operation. Ignition Diagnostic Monitor
The Ignition Diagnostic Monitor (IDM) is a function of the DIS module. The DIS module sends information on system failures to the EEC-IV which stores the information for diagnostic self test. The IDM signal also is used to drive the vehicle instrument tachometer, and test tachometer for system
Nov 19, 2010 | 1991 Ford Mustang
I cant get my own image on to my wallpaper or screensaver for my lg KP500 ive tried switching to external memory and i have an 8gb memory card but it just didnt work ... Help ...
I 2 faced dis prob but got solved doing dis: resize the photo to 240x400 pixels & apply it...... Njoy......
I think dis s cuz of the image size nly....
May 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
HEY BRO
Im just wondering, are you a kid, because your writing in text message form! Try getting the reset disk offline as an iso image, you will also need a dvd drive, dvd-rw, and and iso burner(this is free)! Then burn it to the disk!
Oct 12, 2008 | HP Pavilion dv1000 Notebook
My dis will not eject
there should be a small pin sized hole to stick like a pin in to eject it out.
Jan 21, 2008 | Nintendo Wii Console
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
