Question about Ruud UHSA-HM1817AA 1.5 TON AC/HP FAN COIL
Fan not running
Fan not blowing
    Master:
  • 613 Answers
Check the fan's run capacitor.
Posted on Dec 08, 2013
Testimonial: "Thanks. I replaced the run capacitor and blower motor, and it's working great."
My tower fan doesn't blow air Everything else works so its not the motor Why is this?
Does the fan motor run? You did not say! Did you know that fans don't blow air, even if running, if the fan unit is in a vacuum? There is no air to blow in that situation. So, is any air available to the fan? Is there any air intake location that is clogged or blocked?
Apr 20, 2017 | Tower Dryers
1998 Saturn sl1 keeps blowing 30amp cooling fan fuses. it runs for maybe 20 seconds then fuse blows
The cooling fan motor is likely drawing to much current because it is worn out.
May 18, 2016 | Saturn Cars & Trucks
How to clean fan in hp pavilion touchsmart
You can Clean your Laptop's Fan by blowing air from mouth to the fan's exit while fan is running or you can use blower also. It will blow out all the dust and cleans your Fan. After that you can feel the smooth running of your laptop's fan
Nov 10, 2013 | HP Pavilion Computers & Internet
Ac/fan stopped cooling/blowing/ i hooked up red & green wires and fan blows. now what?
Just to understand what you are saying; You are hooking a wire between the R terminal & the G terminal on the fan control board and the fan runs. When you turn the fan on by the thermostat is does not.
Assuming that you have 24 volts at the G terminal (or wire) at the air handler/furnace when the fan does not run, I would have to say, based on the information that I have been given, that you have a bad fan control board.
Nov 20, 2011 | Heating & Cooling
My cooling fan fuse on my Honda 2007 VFR keeps blowing. I replace the fuse and the fan runs for several cycles but eventually blows again. The fan appears to be running fine with now apparent slow down or...
The fan motor can be going bad. BUT, check the wiring to the fan along the frame for rubs or brake in the insulation and check the plug for a burnt connection. Any loose connection can cause enough heat to blow the fuse. Check all this. Hope this helps Fix Ya up.
Aug 09, 2011 | 2002 Honda VFR 800
The evaporator fan is not blowing
The evaporator fan should be running. A light frost is what you want to see. Just no heavy frost, that would indicate a defrost problem. Check the fan for power if it has power and it is not running replace it.
Jun 11, 2010 | Frigidaire FRS6R5ESB
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Blows low volt fuse comp and cond fan wont run only supply fan runs
you check the fan motor and the compressor winding and terminal you have a short
Apr 27, 2009 | Heating & Cooling
Ruud UHSA-HM1817AA 1.5 TON AC/HP FAN COIL Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
