Question about Wascomat Parts Wascomat 487 243376 Dryer PIPE,WITH GAS VALVE-T50 - Wascomat Laundry
Dryer vibrates a little - Wascomat Parts Wascomat 487 243376 Dryer PIPE,WITH GAS VALVE-T50 - Wascomat Laundry
    Genius:
  • Wascomat Parts Master
  • 2,415 Answers
-Make sure all leveler are touch the ground.
Good luck
Mai
Posted on Dec 21, 2013
WHIRLPOOL QUIET DRY DRYER, VIBRATING HORRIBLY, WHAT CAN IT BA AND CAN I FIX IT WITHOUT AN APPLIANCE REPAIRMAN
Lots of things can cause vibrations so there is little point guessing. Most of those things are inside the cabinet and variable amounts of dismantling is needed for access and some dryers need the cabinet almost entirely dismantling for relatively simple jobs.
Whether you can fix it or not or even should attempt to depends entirely on your experience and ability.
Mar 07, 2018 | Whirlpool Dryers
Can I wall-mount a Hoover Aqua vision tumble dryer?
Depends on the wall. Unless solid masonry it would be better standing on floor-standing racking or a platform.
I mounted our half-size dryer on a home-made shelf above our chest freezer as a space-saving measure and given the space and a very substantial wall there is little reason why a full-size dryer should not be similarly mounted.
The cabinet of the dryer is not rigid enough for direct wall mounting (if it was it would be far too heavy) and so it must stand on a shelf strong enough to support the weight of the machine and the load and the shelf must also be capable of absorbing a certain amount of vibration and be purpose-built to prevent the machine rolling off due to the vibration or internal forces.
I don't know of any commercially-built shelves for the purpose so one would need constructing, probably from a mixture of timber and steel or aluminium and the whole very firmly anchored to the wall with through-bolts if possible or resin-bonded anchors or similar. Ordinary plugs and screws would not be suitable.
Jul 22, 2016 | Hoover Dryers
Frigidaire electric dryer front load . Bad vibration
Good Afternoon David,
I understand you are receiving a bad motor vibration on your Frigidaire dryer. I see that you replaced the fins on the blower, only to have them break again. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the vibration noise, as well as the blower fins to break. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Electric Dryer
Little water
How are your controls set?
Jan 18, 2014 | Frigidaire Affinity FAFW3801LW 27"...
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
Got the phone a little wet and now the vibrate function will not turn off. Whether the phone is on or off it vibrates.
this like your phone has short circuit caused by the water
open your phone then use hair dryer to the phone board to make the board dry and the water disappear
if this can not solve the problem, contact service center
Feb 19, 2011 | LG TracFone 600 Cell Phone - TF600GP4
Excessive noise/vibration
Vibration problem occurs on dryer/washers because of bad dampers generally. When drum is loaded, the load is distributed randomly, so its create vibration when drum spin in certain revolution. The dampers are supposed to take this vibration and minimize them.
There are more possibilities like drum dislocation or bended drum etc.
Jun 28, 2009 | Kenmore 73932 Gas Dryer
Vibration
Normally, I find lint stuck in the fins of the blower that cause it to vibrate. remove the front panel to access blower.
Jan 27, 2009 | Hotpoint NVL333GY Gas Dryer
Drum vibration
The installation instruction on the pkg. should offer some insight as to usage of a lubricant, what type, and how much. Different mfr's. use different metals in their bearings/pads and the wrong kind can cause lube to spread in all the wrong places.
Oct 24, 2017 | Dryers
Cloths dryer problem
ok " your dryer should have it's own line, make sure nothing else is pluged into that line.
may have other devices drawing amps.
Jan 16, 2008 | Dryers
Wascomat Parts Wascomat 487 243376 Dryer PIPE,WITH GAS VALVE-T50 - Wascomat Laundry Logo
75 people viewed this question
Top Wascomat Parts Dryers Experts
Dan Webster
Dan Webster
Mai Lor
William Goodman
William Goodman
Level 1 Expert
Are you a Wascomat Parts Dryer Expert? Answer questions, earn points and help others
