Question about Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129
Problem with top/low adjustment screws on shimano gears
Having problems shifting up gears on the front deraillier.Shimano say to turn adjustment screws but the are not touching anything even when screwed all the way in.How do I get the screws to touch the other componants and so adjust the gears?.Any help is greatly appreciated.
  • 38 Answers
Forget the screws as those are more for fine tuning once you are close to having it set correctly. Where the shift cable connects to the shifter on the bars you will typically find an adjustment knob (note that you may have the same type of adjustment knob where the cable meets the gear shift mechanism also) which the cable rides in. You will make much larger jumps in adjustment when using this method as opposed to using the screws located on the gear changing mechanism. Best of luck to you on the fix!!
Please be sure to rate this solution.
Regards,
Joe
Posted on May 08, 2009
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
I have replaced the cable on the 7speed Shimano SIS derailler and Ithink I ran the cacle through the shifter wrong. I can only get three gears to shift. This is a combo brake and shifter handlebar mount.
All shimano derailleurs have two small screws located on the mechanism itself that allow you to adjust the position of the derailleur relative to the gears. The top one adhusts how far towards the wheel the chain can go and the bottom of the two adjusts how far towards the stop it goes.
Put the bike on a stand or just prop it up so the rear wheel can spin freely when you turn the pedals by hand
Put the shifter in the highest gear and turn the pedals, the adjust the top screw until it enters the top gear, you may need to adjust the cable tension also to do this.
Once you have it going easily into and out of the top gear adjust the bottom screw so that it easily goes into the bottom gear.
You should be done! Don't forget that for the first few rides the cable will stretch out a little so you may need to tinker with those screws a couple more times.
Hope this helps:)
This website might help you also http://sheldonbrown.com/derailer-adjustment.html
Jul 18, 2011 | Shimano Lx Rd M580 Rear Derailleur
My Shimano TX-31 is not lined up correctly. When I shift into 7th the chain comes off because the Derailer goes beyond the 7 sprocket. How do I adjust this? It is also causes a clicking sound when in 1...
There are two screws that limit how far the derailer travels in both directions. Yours is apparently traveling to far out, and not far enough in. See the diagram at the link below. The two screws are identified by number 3. You will need to adjust both of them. With the chain on an intermediate gear, try turning one of them them 1/4 turn, then check the result. You'll soon get it right. Good luck. If you found this useful, please vote
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-TX31-2753B_v1_m56577569830637983.pdf
Sep 01, 2010 | Shimano Cycling
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
The front derailer will not stay in gear. It
check the shifter handles also check your cables and cable covers check anchor bolts frame clips anything that can cause your cables to come out of adjustment shimano is quality stuff so start at the shifters and work back to the derailleur .hope this helps
Nov 23, 2009 | Shimano Deore LX Mountain Bike Front...
Shimano total integration shift levers will not hold the front deraileur in the high gear position. Slips back to inside, small, front sprocket immediately. I have tightened both the allen screw on top of...
Try this site:http://www.parktool.com/repair/byregion.asp?catid=53 Read the articles on shift levers and derailleurs especially. Good photos.
Oct 19, 2009 | Cycling
Unable to select bottom gear shimano 100gs
Here is a link to a tech sheet for a Shimano Deore rear derailleur. It is not your exact one, but all Shimano derailleurs are more or less the same. Make sure you have thoroughly cleaned your drivetrain with a degreaser (like Simple Green) and a brush to clear all grease and debris before making adjustments. The second step is to shift into your highest gear (the smalles cog) and then release the cable in the derailleur, pull taut and retighten it. Check again to make sure you can not get into low gear, because it may have been a problem with cable tension, which you just fixed. If it still does not, then adjust the "L" setting on the derailleur so that the jockey wheel on the derailleur will move just ever so slightly past the last cog on the cassette when the shifter is fully engaged.
Hope this helps,
matt
Oct 08, 2009 | Shimano Cycling
I have a shimano tourney deraileur with sis index. what does the small adjustable screw which is off by itself adjust. the other two screws are for the upper and lower gear stops.
Is it a long screw running into the derailleur hanger? This sets the distance from the cassette to the jockey wheel. You use it to pull the jockey wheel away from the large cassette cog if the chain is having trouble clearing it. You'll know if it is happening because the bike will be making more noise in the low gear and it will sometimes want to skip out of gear.
Sep 13, 2009 | Shimano Cycling
I'm trying to adjust the shimano gearing on my trek bike and am having a little trouble
Front or rear? What is it doing?
Flip the bike over onto the handlebars and saddle and let us fix it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 02, 2009 | Cycling
I have a Shimano Deore XT rear derailleur. At the moment it moves easily between the bigger cogs but doesn't move every time I change gear between the smaller cogs. For example, when moving from smallest...
The screws on the derailleur set the positional limits for the derailleur; if your description is accurate and it is always one position behind until the middle gears, I would guess it is not these screws causing the problem, but rather the cable tension is a little to low. There is a typically a knurled knob on the back of the derailleur that can adjust cable tension. Unscrewing it a little will tighten the cable. There may be other adjusters if you follow the cable up to the shifter. Try changing it in small increments (eg 1/8 to 1/4 turns) and go through shifts from high to low before determining if it is helping or not.
Jun 27, 2009 | Shimano Deore Xt Thumb Shifters 7...
Mountain Shimano Alivio Front Bike Derailleur Bicycle Part 129 Logo
1,078 people viewed this question
Top Mountain Cycling Experts
John Egan
John Egan
Lawrence Oravetz
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
