Question about Dometic Rooftop RV Air Conditioner
MY FURANCE WILL RUN BUT ONLY COULD AIR COMES OUT . AND YES IT IS ON HEAT
  • brlaurent61
    brlaurent61 Nov 26, 2013
    HELP PLEASE...I have 94 jayco camper . In the middle of a ice storm and in my camper. My heat will only blow out cold air . What can I do to see if what is wrong. ALso pregant.. hubby out working
  • Dometic Master
  • 6,674 Answers
Does the furnace run through the day at all when sun is out?
Posted on Nov 29, 2013
How many square feet does 50,000 BTU forced air furnace take
One BTU is sufficient to heat about 55 cubic ft. of air by one degree Fahrenheit.
With good insulation, it's about 75 BTUs per sq/ft
With poor insulation, about 300 BTUs per sq/ft
Oct 04, 2013 | Health & Beauty
No heat.. trying to see why.. gas goes on ands ten off in 10 seconds.. the yellow perge light is flashing - maybe related.. help?
Flame sensor at furance nees to be cleaned. Remove front top cover at furance. Flame sensor is located left of last burner .Remove 1/4inch screw and clean wirh fine steel whole.
Feb 03, 2011 | Honeywell Electronic Programmable...
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
I have a propane furance in a mobile home. When I turn the thermostat up the furance comes on a heats the room to the set tempature. after the room cools back down the thermstat clicks but the burner will...
if you are getting power to the gas valve, then all of the safety switches should be closed. if you have any drain lines off of the inducer fan and at the bottom of the heat exchanger, make sure they have a trap and have water in them. the pressure switch may be the culprit.
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Furance not staying on
The flame sensor is not sensing flame.
You can try cleaning it, but will probably have to replace it.
When the sensor does not detect flame after ignition, it will shut down the gas flow.
Oct 01, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
The coil in my byrant furance is freezeing up , my ac has been running for hours and i noticed that the house was not cooling down. when i checked the furance i noticed ice on the outside of the coil above...
Low on refirgerant, or dirty coil, or it was run on a cold night. Either way, the only way to take care of it is to start by running the fan only, and shutting the cooling off. This will melt the ice on the coils. It is going to make a mess. Have the unit serviced if it is not dirty, if it is dirty clean it with an approved cleaner. Your local hvac repair shop should be able to recommend a good cleaner.
Jun 09, 2009 | Heating & Cooling
FAN MOTOR CONTINUES RUNNING AFTER HEATING CYCLE IS COMPLETED BLOW
Check the thermostat. Make sure it is set for AUTO fan not ON fan. If that is OK replace the fan relay.
Apr 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Intertherm electric furace
It sounds like the coils are fine if you are getting heat. They are likely shutting down from overheating after being on for awhile. Check your filter and overall air flow to make sure it's adequate.
Mar 03, 2009 | Intertherm P3RA-048K Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
32 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
