Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Black Ink wont work.
I havent used my black ink in like a year. I bought the same printer I use to have and put my old black ink in because it took the same kind, but the ink will not work. Should I got out and buy more? Its not empty, the computer says its over half way filled so...Is there anything I can do???
  • 38 Answers
I would take the ink cartridge out, grab some rubbing alcohol and a q-tip, and wipe the bottom of the cartridge where the ink gets dispersed. You should see color on the q-tip after just a few swipes. Return cartridge back into printer and give it a go!!
Please be sure to rate this solution.
Regards,
Joe
Posted on May 08, 2009
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Hi havent used this printer in a while and set it up to my laptop, i tried to print and it wasnt working so i thought that it was the ink as it hadnt been used for a while so i went and bought all new...
Remove and then replace the black ink. Make sure you remove any sealing tape that may be covering holes in the ink cartidge. While the ink cartidge is removed, you might also want to give it good shake. Finally, the cartrice may juat have been too old - they age even when in the packaging, and most have an expiry date.
Nov 08, 2017 | Epson C64 InkJet Printer
I bought a Brother MFC 210C Printer - Fax - Copier a few years ago, when it ran out of ink I stopped using it for awhile. I just bought new ink cartridges, took the tabs off and put them in and they are...
Perform reconnection inspections on the printer. Attempt to printer documents. The computer should diagnose the condostion either as missing programs or malalligned printer ink or paper or compartments not closed appropiately.
Jan 29, 2011 | Brother MFC 210C All-In-One InkJet Printer
This is the 1st time I had to replace an ink cartridge since I bought this Canon MX310 last year, and since I never used the color, I just went out and bought a black cartridge. Now the window is showing...
Ink cartridge always has an expiry date like medicines as you had told that its an year old & you never used the cartridge so their could be a possibility that this might be gone expired. So please check the expiry mention cartridge.
Oct 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Changed ink and now the printer wont print
The old ink has probably dried, plugging the jets. Try going through the cleaning cycle (several times if necessary). If it begins to print at all then let the printer set overnight and try cleaning again.
Fred
May 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hi, I have an epson stylus cx6600 , I replaced the black ink and the pages printed afterwards were full of lines, I cleaned the nozzles and cleaned the heads twice. I then took out the black ink cartridge...
Did you put a new cartrige the first time, or just put ink in the old one? Ink cartriges dry out. If you let them sit for extended periods of time, you don't save ink, you let them dry out. You can try to bag and wrap them if you are not going to use for awhile and see if they keep longer...but usually you just have to get a new one. I've heard you can put tape over the end of it to keep it longer...don't know from experience though. New carts will usually do the trick though.
Jan 12, 2010 | Epson Office Equipment & Supplies
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
No ink onpaper
very possible - what type of printer? - ink jet? if so change the black and if it works then replace the other colors - also run the cleaning of the heads
Apr 16, 2009 | Office Equipment & Supplies
My printer will not print text.
Did you try and change the ink cartridge mode from color + black to color, or vice versa? Another thing you can try is to "prime" the ink cartidges by taking them out of the printer and gently pressing on the print nossels to get the ink flowing, then put the cartridges back in the printer.
http://www.techwaredist.com/repairshop.asp
Dec 09, 2008 | Primera Technology Bravo II DVD Duplicator...
Black Won't Print On MFC 420 CN
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Sep 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
