Question about Refrigerators
Haier fs120252l fan - Refrigerators
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
Wine fridge is always running but never cools below room temperature.
the processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Dec 30, 2012 | Haier HVTS18DBVS 18 Bottle Dual Zone Wine...
When I turn the air conditioner off or on it makes a noise sounding like it is coming from the fan. It sounds like the fan might be loose but I'm not sure. What is the problem and what should I do?
Hello, you would need to take the top cover off the AC and check the fan, usually the hub of the fan breaks and becomes loose or sometimes just the clamp comes loose and the fan hits the housing. If the fan is cracked then you would need to replace just the fan on the unit. Here is a link or parts to your ac http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/ESA3109.aspx.
Jun 13, 2011 | Haier ESA3109 WallWindow Air Conditioner
Haier Airconditioner HWR10XC5 Fan not working Does it have a fuse or relay
If the fan is not working you will want to test the selector switch and the capacitor. It does not have a fuse relay for the fan.
Apr 07, 2011 | Haier HWR10XC5 Air Conditioner
Lost the remote to our hwr05xc6 haier air conditioner
mcdevito75 here, I belive your mom is right, temperature and Fan?? must be set manually, Fan speed I,m not to sure about. Contact Haier online, www.Haier Air Conditioner.com or see any A/C shop in your area.
Jul 20, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Haier HVT12ABS Not cooling noisy motor
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you bought it before 2006 you have 1 year parts and labor, and 5 years on the motor ! if you called them and they told you one year, they must not have known the date you bought it!
Try the manufacture!!!!!!!!!!!!!!!
They will have the part
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Please rate me solved before you sign off.
Thank You
Sep 14, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier htq18jaa fan replace
First make sure your door switch is okay. Other problems could be your defrost timer, evap. thermo. etc.. Make sure that it is your fan before replacing it. To replace it you take everything out of the freezer and remove the rear panel. You should see the fan at that point. You can check for voltage at the fan by disconnecting it and measuring for 125V at the leads. If when the door is closed you have power replace the fan. If not check all other possibilities.
Dec 26, 2007 | Haier HTQ18JAA Top Freezer Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
