How to i get the timer on a Fujitsu Halycon inverter to repeat every day?
I have a wireless remote, model AR-RAH1U
  • 90 Answers
Is not possibily,to any ac.the timer run just for 24 hours.on the power surce of your ac you can make a timer control programms, who take or give energy to your ac inverter(you put the ac inverter to run , and when the energy is shut down ,the ac inverter is stop working and when the energy is come back the inverter start working)
Posted on Dec 28, 2013
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
notsomot
  • 67 Answers
SOURCE: my fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Posted on Jan 08, 2009
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
  • 634 Answers
SOURCE: fujitsu air conditioning remote control not
open the remote and carefully look at where the batteries make contact they sometimes bend in and dont make contact just pry them out a little and reinsert batteries and it often will work again
Posted on Jul 07, 2009
How to turn the Timer off on Fujitsu AC Model AR-RAC3E? I have tried several times but failed. The Timer light flashes three times every several minutes. The AC does not work at all. The Operation
remove front cover-pull from bottom and lift up at top reset button is above lights try that first , other checks remote battery, control wires 1-2-3 from condenser to evaporator board.
Jan 20, 2015 | Fujitsu Heating & Cooling
How to turn off the timer on the Fujitsu AC Model AR-RAC3E?
Hi Rismita,
I hope the following link is helpful for you
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Jan 18, 2015 | Fujitsu Heating & Cooling
Directions for setting Fujitsu wireless remote AR-RED1U
If you type this into Google "Directions for setting Fujitsu wireless remote AR-RED1U", you will get information on how to do what you want to do.
Oct 29, 2013 | Fujitsu Televison & Video
My fujitsu halycon inverter is dripping water in the house. How do I fix it?
First checking out the drainage that comes out is not blocked, and secondly need to open the air conditioner and clean the Wading and finally the third and final case to see if the machine has Freon.
Sep 20, 2011 | Fujitsu 24C1 Air Conditioner
HOW DO I SET THE TIME on Fujitsu AR-RY3
Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
Dec 09, 2010 | Fujitsu 36CS Air Conditioner
Manual for Fujitsu plasma inverter Model ASTB09LDC
Fujitsu Plasma ASTB09LDC, has the operation and timer leds flash 4 times then the timer led flashes 3 times then cycle repeats. What does this mean?
Jul 28, 2009 | Fujitsu Heating & Cooling
Dec 01, 2007 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
