Question about Philips Televison & Video
PHILIPS MAGNAVOX Picture Color Off
I have a RP PHILIPS MAGNAVOX MODEL 9P5034C102. The picture was off ALOT. The picture isn't crisp, and it seems that Red is overpowering all the other colors. I've read online that it could be the convergence on it's way out or that the blue & green need coolant. Any ideas?
  • p_celani May 08, 2009
    I tried that and thank you for posting and your input. What happened when I did that was the 2 other colors took over, there wasn't an even balance. I got it now where the letters are crisp so you can read them, but everything seems orange. I was told getting TV coolant for the 2 colors will solve this issue, is that correct?
  • 68 Answers
Hi i hope i can help you?. please check the arial connection. may i please ask you if you open up . go to where the red light is and check for any adjusters.if you find turn down the red top tip if you use a mirror and place in front of the tv and tha t way you will see what is hapining.
Posted on May 08, 2009
Fuzzy with double picture
TV is blurry as if expanded, do not know how this happened. Words are blurred, picture is not crisp anymore. Help please.
Aug 12, 2010 | Philips Magnavox 27MS343S 27" TV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
My t.v pic zooms in and out and the color is red dominated.
1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 also you probably need a fluid change
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 27, 2009 | Philips Magnavox 9P6034C 60" Rear...
MAGNAVOX PROJECTION TV- GOOD PICTURE , BUT NO COLOR
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-ptv900-series-ssm/cName/sale-items
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60... Problem
You need to change the coolant in the CRts ( picture tubes) you can get the Phillips coolant replacment kit at the following link with the coolant and the instruction CD with step by step instructions on how to do the replacment with pictures. Its listed under the repair kit category. Heres the link.
Aug 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips/Magnavox - Model 9P6444C105 - "Yellow-ish Haze" on Screen
You can get the entire coolant replacement kit at the following link. which contains 48 ounces of coolant and an instructional CD that explains the process step by step with pictures. Its listed under their repair kit catagory.
Here is the link.
Jul 28, 2008 | Philips 64PP9901 64 in. Rear Projection...
UNABLE TO BRIGHTEN PICTURE
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Jan 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
146 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
