Question about Suunto Scuba Diving & Snorkeling
Dive computer manual
After every dive its give me ( A ) in dive tables ... what is the problem ??
What are the different types of dive computers?
The two main types of dive computers are wrist dive computers and console dive computers. Wrist dive computers are actually just like wrist-watches (a little bigger) and are worn on the diver's wrist. Right now, they are smallest dive computers available.
Console dive computers are attached to the diver's equipment by a hose. Main difference between console dive and wrist dive computers is that console dive computers include pressure devices in them.
Feb 06, 2013 | Scuba Diving & Snorkeling
Problem E 6 comes up on my uwatec smart com
I have a smartcom very nice dive computer this issue can ONLY be repaired by scubapro themselves the smartcom is obsolete they will give you trade dollars toward a galleo or luna which are better dive computers
Feb 05, 2013 | Scubapro UWATEC Smart Com Console Dive...
Can i adjust the spring on my diving board?
for home diving boards, the fulcrum is usually unmovable because giving too much spring can be dangerous. on professional diving boards, the fulcrum can be adjusted to be more or less springy
Jan 28, 2013 | Pool & Spa
I am using tata docomo sim in my delta q20 phone.how do i connect to internet . there is no inbuild settings like vodafone,airtel
type internet send it to 52270
or
type DIVE-IN send it to 52270
incase this is not working kindly mail me on ajinkyapai@gmail.com
i will provide u manual settings
May 08, 2010 | Delta JT160 Shopmaster 10 Amp 6 Inch...
I have a two socket table lamp that is old. I
dive in , it is basically the same... without going into excrutiating detail... there will be a joint somewhere to connect the two sockets together..try this website http://www.mylampparts.com/
Oct 30, 2009 | Lamps Plus ACE TABLE-TOP DIMMER For lamps
How do you adjust the cobra to be more lenient or conservative
You can make personal adjustments to 3 different presents. This is explained on page 38 of the manual located at the link below.
http://media.suunto.com/media/suunto/manuals/en_US/cobra_manual_en_v3_m56577569830658693.pdf
Mar 09, 2009 | Suunto Cobra Integrated Computer
Why do scuba diving pressure gauges reach 5000 psi if a tank may only be filled to a max of around 3200?
Scuba tanks can be filled well past 3200psi. When they do a hydrostatic test it is well beyond any pressure that any dive shop will fill a tank to. The highest I've seen the pressure get in my tank is 4000 and that is when the filler at the dive shop forgot about it.
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Problem
Just bought an aqualand, and it seems it gives you the word check if you put it in dive mode and dont go in the water for 1 hour. My problem is similar, it goes into dive mode, and I cant abort it. So I just leave it untill it says check, and eventually it disapears and returns to normal.
Oct 19, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
How deep can I dive with this watch
Per "Sector" all of their watches are "water resistant to a minimum of 300 feet". Note that they do not say "water proof".
Aug 20, 2007 | Sector 450 2653450035 Wrist Watch
Scuba Diving & Snorkeling Logo
76 people viewed this question
Top Suunto Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Suunto Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
