Question about Cooktops
Sauter induction displays "F"
2 of the 3 plates keep on flashi g with "F" when turned on. What could be the problem? I did not do anything different than before...
We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
Feb 07, 2016 | Miele Cooktops
E9 being displayed despite using induction kadhai
Try resetting the unit by turning your circuit breaker off and back on.
Dec 01, 2015 | Cooktops
Displays error 40. Why won't it turn on?
Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
INDUCTION STOVE
I have Bajaj Induction Cooker MAJESTY ICX 2 model. While it is working suddenly the display shows E4 and heating stopped. the on/off switch also not functioning. Pl. tell me how I will repair the cooker and what spares are required for repairing.
Thank you,
Susanta Banerjee
banerjeesusanta8@gmail.com
May 27, 2013 | Max Burton 6015 Portable Induction Cooktop...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
