Question about Vision Fitness Exercise & Fitness
How do I fix E5 error on my Vision Fitness T9450 treadmiill
  • 20 Answers
The primary cause of E5 is the elevation system malfunction - Elevation error (signal lost)
First check all wires from the elevation motor to the lower motor control board. Also check the main wiring harness from the console to the lower motor controller to determine if a wire has been cut, pinched or shorted to ground.
If all wiring is in perfect condition and the unit has not been recently moved, dismantled/reassembled, then there might be a failure of the lift motor itself, or in some cases the motor control board (controller)
Posted on Nov 30, 2013
4 Suggested Answers
  • 26 Answers
SOURCE: I have the Vision Fitness treadmilll #T9450. When
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Posted on Jun 16, 2010
  • 9 Answers
SOURCE: I have a vision fitness T9450 treadmill. My wife
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Posted on Aug 05, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Vision Fitness T9200 Treadmill
How do I fix an E5 error on T9450 Vision Fitness Treadmill
follow this steps and fix it. God bless you
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Nov 26, 2013 | Exercise & Fitness
My Vision Fitness T9450 is having a power issue. I plug it in, turn on the power button in the back, the console lights up as normal. Then when I press start the power goes out before the belt even st
you have a SHORT circuit maybe in the power supply, transform, capacitor, motor or lower board.
You must call some tech qualified, for to fix it.
see the block diagram.
God bless you
Sep 19, 2012 | Exercise & Fitness
How do I fix an E5 error message on an Ironman 2300.1 treadmill? What does this error message mean? How do I get a manual for this treadmill?
go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
E5 means a key stuck ,some Upper PCA has been failled.
Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 30, 2012 | Ironman Exercise & Fitness
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
I am an Electronics Technician but have never worked on a Treadmill. Do you have any tips on removing the console and getting to the membrane keypad? Vision Fitness T9450 The buttons on the touch pad...
look at your manual for the blow out picture remove the rite screws and have some one help you hold the console while you disconnect the wire harness
Feb 26, 2011 | Exercise & Fitness
Jun 15, 2010 | Dmm Vision Fitness T9500 Treadmill
Exercise & Fitness Logo
271 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
ray gallant
Don Eagan
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
