Question about Electrolux Frigidaire Fridge Defrost Timer 215267800 215846602
Electrolux fridge temperature control displays a "square"
The display of the fridge displays a "square" instead of a temperature measured in Celcius. The manual just says this is a repairman issue. Fridge is working ok though except it gets a bit to cold. Freezes stuff thats to close to the back walls. Any clues?
    Top Expert:
  • Electrolux Master
  • 12,962 Answers
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Posted on Nov 28, 2013
  • 1314 Answers
SOURCE: Electrolux icon Stainless Steel Temperature issue
ok you have a defrost problem the freezer does all the cooling for all the unit both sides give me a few and ill give you the procedure for finding out which part needs to be replaced
Posted on Feb 20, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
SOURCE: looking for a frs22zrf service
Hi there!
You should be able to identify various parts Here
It sounds like a problem with defrost timer control, but may also be the control board for the thermostats.
Just click the link , put in Electrolux, fridges, then electronic parts in the box at the bottom.
(shop around before you buy, and try removing/ testing items before purchase)
Posted on Jun 28, 2008
  • 1462 Answers
SOURCE: I've got an electrolux frost
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Posted on Aug 05, 2008
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
How do I regulate the temp in the display fridge. It's too cold at 1 deg C
Ideal Temperature is between 34-38 degrees Farenheit. 1 degree celcius converts to 1.8 x 1 + 32 = 33.8. This is ABOVE freezing and should be Perfect...
Oct 21, 2014 | Refrigerators
Fridge keeps powering on and off
Your controller board is about to die. Call an appliance repair center and see if the board is user replaceable. Be prepared for sticker shock, the part is going to be expensive, unless it is under warranty.
Mar 19, 2014 | Electrolux EI26SS55GS Stainless Steel ...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
How do you Change Fahrenheit to celcius on electrolux fridge?
Good Morning Lize, thank you for allowing me to assist you!
Generally speaking, Fahrenheit to Celsius temperature can be change by pressing and holding the Fresh Food up arrow while at the same time pressing the Freezer up arrow three times in five seconds. I ask that you please follow up with a response on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully
Thank you and best of luck!
Oct 15, 2013 | Electrolux Refrigerators
Reading the wrong tempeature
Centigrade (celcius) metric temperature .
19C = 66F, 20C = 68F 21C= 70F approx.
25C= 77F, 30C = 86F. There should be a setting to change that to Fahrenheit.
Jul 17, 2009 | Maytag M6Q10F2A Air Conditioner
Changing panel display from farinheit (sp?) to celcius
Hold the colder button for the fridge and the colder button for the freezer both for about 3 to 4 seconds. It should change to C.
Dec 25, 2007 | LG LRFD22850ST French Door 22.4 Cu. Ft....
GE profile fridge
Are numbers being displayed at all? If you want to confirm whether they are wrong or not, try putting a thermometer inside the fridge for about 10 minutes and check it against the temperature displayed. If it's wrong then it's probably the temperature sensor and would need to be replaced.
I suppose it's a long shot but could it be displaying 18 and feels more like 65? (Celcius vs. Farenheit)
Nov 08, 2007 | GE (JASHO96273)
Electrolux Frigidaire Fridge Defrost Timer 215267800 215846602 Logo
119 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
