Question about Garden
Flymo ec 600 easicut sudden cut out - Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Cut through cable on flymo how do i rewire
it best to get a waterproof cable connector then you do not have to take the flymo apart.
Apr 10, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
HOW DO YOU REMOVE THE COVERS, THAT ENCOSE THE MOTOR ETC., FROM A FLYMO EASICUT 510? . I HAVE REMOVED ALL THE SCREWS BUT THE COVERS WILL NOT COME APART. HELP PLEASE.
Have you removed the screws that hold the clear hand guard on.? They should just pop apart once all the screws are out.
Jun 22, 2011 | Husqvarna Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
My Flymo microlite 28 lawnmower is very noisy...
You got it, replace the disc before you use it again.
Jul 09, 2009 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
