Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmrez49 with fault code u61
Fault code u61
5 Suggested Answers
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
  • 11800 Answers
SOURCE: Panasonic DMR-EZ47V combined VCR/DVD has a U61
The service manual says that:
U61 = The unit is carrying its recovery process (with no disk in the tray) . If there is a disk remove it and restart the unit . This is the message that appears when the system's firmware crashed because of an incorrect command - normal operating procedure, just wait for it to finish. If the message doesn't goes away in 10 minutes after a power cycle you should force it: press the Ch UP and Ch DOWN buttons until the DVB Auto-Setup message appears on the screen.
If nothing you do has an effect and you haven't done anything to the unit when this message appeared then the fault is hardware - the processor of the unit has failed. The only way to fix that is to replace the mainboard. But that would cost about $175, more than a new unit, so it's time for a new one.
Posted on Aug 29, 2011
  • 6771 Answers
SOURCE: I have a Panasonic DMR-ES15 DVD recorder. Fault code U61 is showing which is supposed to correct itself but is not clearing.
Only if it's worth it to you, if the unit was fairly cheap, no I would not recommend it, a new unit would give a brand new warranty making it more pleasing, since you had it fixed before it is time to replace.
Posted on Apr 21, 2012
U61 fault on an EZ28
Review the reference U61 in the user manual or maintenance, its posible that its needs format special or type of dvd-ram,
This failure apparently is very common in this brand Panasonic.
you will think twice when You will go to buy Panasonic.
Jun 22, 2012 | Panasonic Televison & Video
Apr 21, 2012 | Panasonic DMRES15 DVD Recorder
Dvd recorder comes up with fault u61 what is that fault and how do i fix it.as it wont do anything till its fixed
I have the same problem. System displays 00000, then goes to 12:00am, then flashes U61...please help
Jun 20, 2010 | Panasonic DMRES15 DVD Recorder
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
ERROR CODE U61 panasonic dmr-ez45v
I HAVE A DMR-EZ45V WITH PROBLEM U61 IS THERE ANYWAY OUT OF IT
May 05, 2009 | Panasonic Televison & Video
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
Aug 30, 2008 | Panasonic DMR-ES35VS
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
U61 CODE WONT GO AWAY
I buy broken units reds repair 870-656-5139
Feb 10, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
